P0335 after rebuild. Cranks, no start.
Just finished up putting my rebuilt motor back in the car all excited to start it up. It cranks but wont fire. I pulled the CPS code w/Evoscan. I checked for spark at #1 but there was none. Pulled the fpr off a little and fuel came out. Pump doesn't prime but will actuate with Evoscan.I really hope its not that damn pita CPS. Its just funny that it went from being ok before I fragged a piston (neccesitating the rebuild) to failed now. Anything else I can check fellas? If it is the CPS screw it, I'll pay someone to change it.
P.S Using a booster pack to start it with would eliminate the battery from being bad, right?
Yikes - Been a month and still nothing, Id have gone insane!
However, have you tried the basics? Charging/replacing your battery?
have you checked to see if the cam sensor is tightened down all the way/plugged in..?
Getting fuel but no spark...
Id say its the Cam position sensor or the angle sensor... those are the last 2 things to try at this point..
Boosted_EvoVIII
59
Jul 1, 2014 10:56 PM
