Cam recommendations big turbo 6262 2.0
Old Sep 4, 2012, 08:56 PM
ChaseH's Avatar
Hello evom.. Please respond if you have experience with these cams.
The car has a street port head, comp 280s, Supertech springs/retainers
1mm oversized valves
Car has a built 2.0 with 6262 making 650whp.. Down for a rebuild and curious if I should swap cams. Want the car to have great top end as its a highway/ drag car. Would changing to another cam gain me anything??
Old Sep 4, 2012, 09:13 PM
Spins_All_4's Avatar
Which cams do you have now?
Old Sep 4, 2012, 09:16 PM
itsmrrizz2you's Avatar
current cams?
Old Sep 4, 2012, 09:26 PM
XTR Performance's Avatar
Can't go wrong with GSC S3's .
Old Sep 4, 2012, 09:38 PM
Teacup's Avatar
gsc s3s are a great choice, along with a kelford 280 or FP5R. If youre more concerned about midrange and spool, a s2 would most definitely still meet your goals
Old Sep 4, 2012, 10:08 PM
ChaseH's Avatar
I'm sorry guys.. car has comp 280s now
Old Sep 4, 2012, 10:15 PM
Teacup's Avatar
quite a few folks have switched from s3s to comp 280s only to notice very little loss of spool with huge gains up top im sure a few will chime in here
Old Sep 5, 2012, 01:02 AM
im a fan of S3's running those with my current build id like to hear or see the difference between S3 and Comp 280s
Old Sep 5, 2012, 07:42 AM
ChaseH's Avatar
Thanks for input so far, just want to make sure the cams in the car are where I should be
Old Sep 5, 2012, 07:47 AM
gpfury86's Avatar
What springs do u have?
Old Sep 5, 2012, 07:58 AM
ChaseH's Avatar
Old Sep 5, 2012, 10:37 AM
masonh's Avatar
S3 for sure
Old Sep 7, 2012, 10:47 AM
ChaseH's Avatar
Anyone else?
Old Oct 16, 2012, 02:53 PM
ChaseH's Avatar
S3 seems to be the winner among forum people but the vendors say stay with S2 unless at 1000hp??
Old Oct 16, 2012, 04:15 PM
Ted B's Avatar
The vendors say what they do because many tend to over cam an engine. They're afraid of missing out on something, but usually end up just losing a bit of power under the curve. In actuality, the GSC S2 is a robust profile that provides 232 degrees of effective duration (1mm), and will support more power than your turbo can deliver. But the cam question isn't what draws my attention...
car has a street port head, comp 280s, Supertech springs/retainers 1mm oversized valves
At this juncture Chase, while you're being meticulous in getting the most from that setup, I suggest prioritizing a full-on port job for that head before going cam shopping. It's the only way one can ever realize the full flow potential of the larger cam sets. AMS made a compelling case for this not that long ago.
Quick Reply: Cam recommendations big turbo 6262 2.0
