evo 8 block with 9 head
i am wondering if the evo 8 block will work with a 9 head. and if so what will i need to make everything work.
i was told harnesses for turbo and some other things
Map performance have a line thay sell to feed oil to the hard for the mivec . Thats the only difference , other than the oil tap on the block every thing is the same , pm me for info if needed .
Not worth the $ ...
I swap the whole long block, You need the main engine wiring harness, IX ECU to make that work. thats about another 800-1k$ better off building a 8 head TRUST me.
If you have a IX & just need a new block... I'd make sure to just get the right block replacement so you have no issues in the future.
Basically the evo 8 blocks are cheaper and more plentiful, but lack the mivec oil feed of the 9 block which is a simple fix.
