Does the double pumper require an FPR?
Old Jan 20, 2013, 02:37 PM
RSGuy's Avatar
Hey guys
Will I need an adjustable FPR if I install the double pumper on a stock fuel system with 1200cc injectors on e85? I know I will need one of I go with a 400lph so that is factoring into my decision. I'd like to keep the stock FPR if I can. Thanks guys
Fred
Old Jan 20, 2013, 02:45 PM
EvoDan2004's Avatar
twin 255 pumps with the reliefs pushed in ''as most BR DP'ers come'' you wil lbe just fine with the stock FPR.
Old Jan 20, 2013, 03:23 PM
RSGuy's Avatar
Sweet thanks Dan! The double pumper will give me more headroom so that's great
Old Jan 20, 2013, 04:12 PM
sparky's Avatar
RS: With the BR Double-Pumper, the secondary pump is staged, as opposed to some other double pumpers wherein both pumps are on full time even at idle.
Old Jan 20, 2013, 07:03 PM
RSGuy's Avatar
That makes sense. Thanks sparky!
Old Jan 20, 2013, 07:10 PM
RSGuy's Avatar
Will I need to Rewire the pumps for more voltage to get the double pumper to work properly?
Old Jan 20, 2013, 07:22 PM
High_PSI's Avatar
Interesting thread. Never know when to get a better FPR or fuel rail for that matter.
Old Jan 20, 2013, 07:29 PM
sktng22's Avatar
I was told i wouldnt need a fpr with a 400lph on the same size injectors. are you posative you need a fpr for a 400lph?
Old Jan 20, 2013, 07:58 PM
sparky's Avatar
What turbo, Fred?
Old Jan 20, 2013, 08:32 PM
RSGuy's Avatar
Sparky, I'm running the ATP stock-location gt35R
Old Jan 20, 2013, 08:35 PM
RSGuy's Avatar
Sktng22, from the research that I've done so far, most of the guys who go with a 400lph overrun their stock fuel system. Also, the walbro dealers/vendors have a disclaimer that says the AFPR is highly recommended with the big pump.
Old Jan 21, 2013, 03:11 PM
EvoDan2004's Avatar
no rewire needed either unless its twin 400s. 255s your fine
Old Jan 21, 2013, 09:09 PM
sparky's Avatar
Don't you mean just the opposite, dan? That is, with the lower volume 255's you may need the 13.8 volts. Probably, I am not understanding your statement though.
Old Jan 21, 2013, 09:26 PM
EvoDan2004's Avatar
With twin 255s a re wire is not needed. I am not saying it won't help but its not needed. Many guys running without a rewire. There is plenty of fuel in the system.
400+lph pumps seem to need one. Why I don't know. Maybe the pump is drawing to much for the factory wire? Or is requiring more volts to run properly? Again Idk
Old Jan 21, 2013, 09:48 PM
sparky's Avatar
Thanks, Dan.
Grip Master
32
Sep 18, 2015 01:09 PM
Darkn3s
E85 / Ethanol
17
Nov 21, 2014 02:11 PM
DvlInDskyz
E85 / Ethanol
Sep 22, 2010 09:32 PM
jid2
24
Dec 7, 2009 09:17 AM
Erik@MIL.SPEC
E85 / Ethanol
Nov 11, 2008 12:46 PM
Quick Reply: Does the double pumper require an FPR?
