Running Lean! Need Hepl!
Old Feb 28, 2013, 06:00 PM
bigdnno98's Avatar
So I just got my Evo out of the shop after an e85 conversion. I'm working with a tuner on an etune right now. Issue is the car keeps getting super lean at high boost. I don't know what else to do. I'm ready to part this damn thing out. Mods are below. Tomorrow I'm gonna try a new O2 sensor in my wideband. If that doesn't work I'm gonna try a new FPR. If that doesn't work I don't know what the hell to do.
Walboro 455lph e85 pump
-6 an fuel feed lines
FIC fuel rail
ID2000cc injectors
Aeromotive FPR
HTA3582r
RNR ramhorn 35r kit
TBE
ported intake and tB
Kelford 272s
Etc
Etc
Please help
I have logs
Old Feb 28, 2013, 06:39 PM
bigdnno98's Avatar
Is using the stock fuel return line going to be a problem?
Old Feb 28, 2013, 06:45 PM
Mrauto50's Avatar
What kind if fuel hanger are you using stock? What kind of fuel pressure do you have at the rail at idle? Are you running E85 now?
Old Feb 28, 2013, 06:50 PM
bigdnno98's Avatar
I'm on e85. Pressure at the rail is around 55-60psi at idle.
Old Feb 28, 2013, 06:51 PM
bigdnno98's Avatar
I'm using the stock hangar
Old Feb 28, 2013, 06:52 PM
RussellDaniel's Avatar
Fuel pump relay could be taking a dump.
Old Feb 28, 2013, 06:53 PM
evo8john's Avatar
How much boost. With that high of base pressure you could be openinig the relief valve in the fuel pump
Old Feb 28, 2013, 06:57 PM
bigdnno98's Avatar
30psi
Old Feb 28, 2013, 06:58 PM
bigdnno98's Avatar
Because of my stock return line my pressure is that high at idle. I was wondering if getting a bigger return line would help lower my base pressure and solve my problem
Old Feb 28, 2013, 07:03 PM
Mrauto50's Avatar
The siphon on the hanger and the return line causes the base pressure to be high. I drilled the siphon and added a 6an return line. If you have a stock FPR I wouldn't do both. Contact Tedb on here if you decide to drill the siphon. He talked me through it.
Old Feb 28, 2013, 07:04 PM
Mrauto50's Avatar
Are you running a rewire?
Old Feb 28, 2013, 07:09 PM
evo8john's Avatar
That puts you at over 90 psi at the pump with pressure drop through the lines. Im betting the relief is cracking open and you are not building more pressure
Old Feb 28, 2013, 07:11 PM
bigdnno98's Avatar
I bought the rewire kit from map and have it to my shop to install when they did the work. I'm going to take a look at it when I get back in town to make sure its wired correctly. I guess my next step is to put a larger return line on so I can get the base pressure down and try that
Old Feb 28, 2013, 07:22 PM
evo8john's Avatar
Have you tried dropping boost to 20 psi to see if it still does it? Then work up a couple at a time
Old Feb 28, 2013, 07:31 PM
bigdnno98's Avatar
I'm trying that tomorrow. Not sure what its going to prove other than the point where it starts
Quick Reply: Running Lean! Need Hepl!
