AYC/ACD fluid change question?
Old Jun 8, 2013, 03:45 AM
babaz7's Avatar
first of all is the AYC/ACD the same thing?
and secondly, if not where are they located and how do i drain and fill them?
and both need ATF SP III right?
Old Jun 8, 2013, 03:57 AM
babaz7's Avatar
and i have no ACD reservoir tank in the engine bay does this mean i dont have ACD?
i have a JDM 2003 evo 8.
Old Jun 8, 2013, 07:45 AM
bbong's Avatar
Quoted from Wiki: "Detail improvements have also been made to Mitsubishi’s own electronic four-wheel drive, to the ACD 5 + Super AYC 6 traction control".
USDM models did not get AYC because of extra bulky emission crap needed to pass in US, but we did get the ACD. To answer your question I don't know, we don't have AYC so I'm not sure which fluid to use there, but for ACD I use Mitsubishi OEM ATF-3 fluid.
I'd suggest googling a little and you'll find the answer if noone here is replying.
Old Jun 9, 2013, 08:29 AM
WRC-LVR's Avatar
check the trunk I thought the NON Us AYC/ACD models may have had one in the drivers side ?
Old Jun 9, 2013, 08:37 AM
SaulHudson's Avatar
USDM 8/9 do not have AYC.
AYC and ACD are not the same, they work in conjunction with each other.
AYC is active yaw control, it is in the rear diff.
ACD is active center differential, its in the tcase
They both use ATF
tephra
Oct 3, 2017 08:09 AM
Chino051
Jun 24, 2017 11:42 AM
BoostNY
Apr 5, 2016 05:23 PM
danfalcas
Feb 4, 2016 08:18 AM
wtz
12
Apr 11, 2003 11:05 AM
Quick Reply: AYC/ACD fluid change question?
