Car wont start after timing belt job Help!!!
Okay so I just did my timing belt on my 03 Evo VIII GSR and now it won't start just cranks and cranks and cranks! Timing is perfect! Has spark! Getting fuel!! Compression is good!! I don't know what else to do!! Also changed the CPS and Crank position sensor! Don't know what could be up! Please any help would be amazing!!!
It gets fuel I pulled a plug to see and it was soaked!! All my sensors are plugged in and right 2nd time I've replaced both of them since I've owned the car! Also sorry for the late responses I work nights!
This sounds like a problem with the cam or crank sensors. I can't recall if its even possible on the 4g63, but make sure it's not installed 180 degrees out of phase. Additionally, if that checks out, reuse your old sensors and see if the car starts.
I'm using the crank trigger plate to get timing perfect in the thread I was using it said everything should line up after 3 rotations but with mine after 3 rotations my cam gears are pointing down and everything else is lined up I've tried retiming just the cams and nothings worked so I'm lost at this point! Any help is greatly appreciated!! I've also put on the serpentine belt pulley for the crank and everything lines up the same besides the cams. Everything on my car lines up after 6 full rotations!
The cams line up every 2 rotations. All three marks besides the cams only line up every 6th rotation. This is a tough one. Just go through and verify every step of the timing belt job.
