Evo 8 IM work on Evo V-VI motor?
Hi, So Im thinking about putting a Evo 5-6 motor into a mirage. they are much cheaper than VIII motor and i am going to use a 5-6 harness. will the 5-6 harness support the VIII manifold and sensors? also, does it have the sensor plugs for EGR and Evap system? If not, has anyone ever installed Emissions stuff on a 5-6? Thanks.
-Shane
-Shane
I don't know about the 5 and 6, but the 4 doesn't have a MAP sensor or a spot in the casting for it, and also does not have an EGR runner (but the head does). However, I have no verification as to whether or not there is a different manifold used on the anti-lag motors, as the one that I have did have that system installed.
Also, sorry about not getting the numbers off my block for you, I walk past the thing a minimum of twice daily and really have no valid excuse, haha. I'll try to remember to PM you tonight if you still want me to.
no egr or evap wiring on 5/6 , evap has just a charcoal canister mounted on strut tower and pipe to throttle body . what test do they do for emissions ??? readiness or tailpipe test. If you use the 8 inlet manifold and 8 ecu you could wire in the egr solenoid
-Shane
I'm trying to pass the VI motor off as a VIII so Id need a egr, eval system and all the rest of the emissions equipment. I guess they don't have to work but as long as it looks hooked up correctly. they do visual and tail pipe here so ill have to shut the CEL on the edu. is there a way to connect a OEM Map sensor to the harness? or just hook it up and tape the wires off to look like it?
-Shane
-Shane
no second o2 in 4/5/6 again you could put one in post cat and wire it in or use the force obd inspection pass
https://www.evolutionm.net/forums/ec...us-mrfred.html
FS[Northeast]: NY: Evo VIII Motor Harness + Chassis Harness *28k*
MisUnderStood
63
Jul 26, 2017 06:38 PM
