threw a cel code p0401 EGR insufficient flow error
#62
evoM is great for this kind of stuff!
#64
Joshs EVO - this hose being off will not keep your car from starting.
My car ran fine enough - I really didn't know it was off except for the annoying code.
I suppose everyones "symptom" is slightly different, but I think the car always runs to some extent.
#65
Thanks, the shop just called me and said that they think that when I changed out the fuel pump and injectors that it erased the code from my key, so they are taking the car up to the dealership to get it redone/rekeyed.
#67
i reconnected one and it still comes back.
are there two vac lines that goto that?
i just got the code and just connected the dangling one i felt.
its really hard to see anything, you just feel it out...
#69
Now this is a resource, no argueing, no bashing, friendly help is what is wanted, Thanks, threw the code couple months ago, cars been sitting in my garage waiting for my attention. Didnt know what the problem was, read this thread found a line un done in the same general area, I hope it was it. I zip tied all the line in the bay area just in case HAHA. Thanks again
#70
Another victim saved by this thread.
Freaking engineers :P
p0401 code, found the vacuum line had popped off... Put the line back on, cleared the code, gtg.
#71
Mitsu, GranMassa, Upstate... looks like I have more in common w/ you guys than just knowing each of you. I experienced this while at Watkins Glen for 2 day track event. I missed 6 of my 8 sessions, so I'm calculating I spent $12.60/min of track time - sucks to be me. I thought I had a misfire somewhere, so I checked spark plug wires, and eventually had NAPA overnight some NGK Iridiums to the track for me, but still the same result. (Wish I'd had net access at the track... )
Limped it the 4 hrs home (sucks to drive with little boost).
Now from what I've read in here I'm guessing that once that hose came off, the car went into safe mode and that's why it felt like I was hitting the rev limiter at 5K rpms. I'm hoping to clear the codes and all will be well once I get the line reattached and ziptied (what a pain it is to try that with one hand - I'll have to take the strut brace off).
Oh well, at least it got me off my butt and over to Harbor Freight to pick up an OBD II code reader ($49 - pretty cheap!).
#74
You are just a boy genius, you are. Anticipating the need to feel deep behind the engine, I stopped my exercise regimen years ago to develop these Olsen Twin-like arms.
Feeling around from the passenger side, I can feel a piece with twin nipples on it (ooh - twins!). While both hoses are attached to the nipples, the one hose is pulled so tight that it is literally bent closed like an "L" right after the nipple ends. That probably isn't good, is it? I'll have to unattach the hose I reattached and see if that relieves the tension. Then it's a matter of getting hose and cutting a longer piece. Where would I pick up hose for this?
