Vendors/people willing to mill two - 10 outputs on valve cover?
After three different catch cans I found one that helps the best, radium. The issue, I'm assuming my crankcase pressure is high because I notice oil/gunk dripping from each hose ends (assuming it's forcing gunk out too quick for stock hose). I'm in the middle of installing a STM - 10 an fitting in the rear pcv side and out catch can stock routing to intake manifold. If this technique doesn't work I'll have to get 2 sides of valve cover milled and tapped - 10 an as well. I'm not comfortable doing this task myself and wanted to know if anyone provides this service? Thanks in advance.
Thanks for the suggestions. After a few days of research I'm going to do either balance shaft breather (b.s. deleted already) or dipstick tube vent to see how those work. I'm not going to chance doing this myself at this point. The - 10an seems to be working great so far but haven't pushed it hard minus a few wot pulls.
Upside - Dipstick no longer has the urge to vacate the block at WOT.
Downside - AN Fitting faces towards the intake manifold. I would have preferred it to orientate towards the shock tower. Nothing that couldn't be fixed through selection of hose though.
3SgteGuru
14
Feb 6, 2007 09:55 AM
