FRESH ENGINE; Fuel & Spark but NO START
Hey guys,
Dropped in my freshly built 2.4LR block in my Evo 9, went to start it up, and it just cranks but wont start.
I have a fresh break-in tune from Tom AKA TSComp so I don't think it's a tune related problem.
I pulled a spark plug and verified that I have spark, and I pulled the return fuel rail, and fuel poured out. I can hear the fuel pump and activate it via the actuator in evo scan too.
I attached some pictures of my timing belt, but I think it's spot on. Tom advised me since I'm using the stock cam gears to have both gears 1/2 tooth advanced.
Checked the fuse block in the bay and the engine fuses checked fine.
Anyone have any ideas on what could be my problem?
It's just me but your one picture it looks to be off time but what do I know. Why did he say to run it half advanced? That doesn't make any sense. AFAIK they should be dead on. My intake cam was off by a tooth and it wouldn't idle for crap. It did run but poorly. Both of yours look out.
Do you have a reading comprehension problem? He said it's a fresh build. I'm quite sure that isn't the problem.
What picture were you referring to being out of time? the trigger wheel? My cam wheels are 1/2 tooth advanced because it's a 2.4LR so it makes up for the 6mm difference of blocks is basically what I was told, and since I'm not running adjustable gears thats how to make it in time is how I understand it.
I'll edit the post if I didnt specify 2.4LR.
I'll double check but Tom disables the immobilizer so it shouldn't be it. Appreciate the suggestion though man!
