Evo 8 transfer case removal questions
Meant to write assembly sorry
Ok so a week ago I found that my transfer case was leaking oil. Drained the fluids and transmission fluid was in my transfer case. After searching around I found that I will have to separate the transfer case from the transmission to replace the little o-ring.
Now I already ordered all the seals/orings(3 for where the transfer case meets the transmission, passengers side seal where the axle goes in and the seal to the driveline). My question is when bolting it up back together should I use anti-seize on the 6 transfer case bolts, axle nut and ball joint nut? Do I put anything on the output shaft when sticking it back in the transmission ? Thanks in advance !
i've never used anti-seize but i do use a high-temp type of grease on the shaft (hehe). it's really thick; almost like wax. it does a good job of keeping that lock ring centered so you don't have a hard time snapping it back in.
I think he means the C-rings on the shafts.
I always use a little axle grease on the axles (seems appropriate) and on seals. I use it on the seals in hopes of keeping them from being nicked. I also lubricate the fasteners going into aluminium with light oil. You need to be careful here as excessive lubrication can cause hydraulic pressure in the threads. Other than that, if you follow the maker's torque specifications you shouldn't need thread locker.
When I first found the leak oil was coming out slowly it was noticeable but not in drops through where the tail pieces(sorry don't know the correct name) bolt up to each other to make the tail of the transfer case. There was oil on the well where the driveline is as well. The transfer case has a breather on top and that will get rid of pressure in my case it was extra oil. So reach up top from underneath the car and see if that is covered with oil as well, mine was covered so that was an another give away. Everything else was bone dry past the tail piece going to the transfer case and transmission.
Since I drained all the fluids about 2 weeks ago, I have been waiting for the seals/o-rings and some time to do this. I found on evom through searching that the little o-ring between the transfer case and transmission is either broken or not there which is causing the oil form the transmission to leak into the transfer case
EvoDan2004
14
May 24, 2013 02:18 PM
konstantinosIX
Jan 8, 2009 11:17 PM
oofastlineoo69
May 18, 2008 08:36 AM
