track / hill climb with a 3586 (or similar) + 2.4L?
I've read a few threads regarding finding the best suited turbo for track racing and hill climb style courses, but few seem to address my particular style of build, and it's 2015, not 2008, so i figured I'd start a new thread to gain some more reliable information.
I'm building a 2.4L EVO 9 motor (few stats on the build below). This car is intended to be a daily driver/weekend warrior. I live in a mountainous region with winding roads that will see snow a few months in the year. We also have a few big highways (Canada has a lot of open space lol). I wouldn't mind driving the car a few days in the winter because why not.
I would like to participate in a few hill climb events in the future. For this purpose I'm unsure if the GT35/HTA35 line of turbos might be too laggy and difficult to drive with, but there-again, given the modern technology provided by the turbo manufacturers these days, and the mid-range capabilities of a 2.4, perhaps it's not too bad a combination?
Ultimately I want to see about 450-550whp on 94 octane with relatively "average" boost (24-28 psi).
I'd be interested to hear what combinations those with experience recommend for a more versatile driving experience. I don't want to build a monster that is basically only good for 'highway moments of glory' or the drag strip.
As you'll see based on the stats, I am leaving the build open to really high horsepower figures nevertheless...
EVO 9 2.4L
100mm billet K1 crank
150mm turbo tuff rods
9.5:1 wiseco assym pistons upgraded pins
balance shaft eliminator
cosworth bearings
cosworth h11 studs
cosworth head gasket
supertech valvetrain
kiggly beehives
GSC R2 mivec cams
curt brown ported/polished head
curt brown ported intake manifold
curt brown ported throttle body
ETS 4.0" intercooler
ETS 4.0" speed density
ETS exhaust manifold (this will depend on turbo choice of course)
twin 450 fuel kit
FIC 2150
-8an feed, -6an return
RCI fuel cell
EDIT: Hmm well the 3586 does see hill climbs, no doubt. Probably one of the most famous events at Pikes Peak involving an EVO, in fact... Jeremy Foley's Pikes Peak EVO 8 ran a 3586, 0.82a/r. 2.3L build with 9.0:1, E85. http://www.motoiq.com/MagazineArticl...-Peak-EVO.aspx (don't know if this is a good example though? )
EVO 9 2.4L
cosworth bearings
cosworth h11 studs
kiggly beehives
GSC R2 mivec cams
twin 450 fuel kit
FIC 2150
RCI fuel cell
Haven't considered Borg Warner at all actually - I know very little about their turbos.
EDIT: It seems that although the transient response for a turbo of this size is virtually unmatched (as far as i can tell from brief reading), the 8374 would require a custom manifold and some ingenuity to have everything fit properly, is that basically correct?
No advice on the turbo as an hta3586 should do quite well. But I would be using 156mm rods since you're using the 4g64 block...
no i had it on my car (2.4 , R2 and 8374) now ive moved on to 9180 with 1.45ar. Just testing it out, the 8374 is going to be hard to beat. Loved it, but back to the point, i think it would also make for ultimate hill climb set up. And you better know how to drive cause its going to be a handful and fun non the less
Thanks for sharing your experience - makes me even more excited to go for this turbo
I'm also about to build my evo 9 for hillclimb and I'm stuck with the turbo choosing..
it is pretty sure that I'm going with efr but don't know for sure because less experiance in the external internal gate thing
so plz help me decied
Spec-OpsMotorsports
23
Jan 24, 2014 09:58 PM
DaveK
Aug 31, 2009 12:35 AM
DaveK
Automotosports - Illinois
Aug 12, 2009 09:55 AM
