Car is jerking when releasing the gas pedal
Old Nov 29, 2015, 05:12 AM
araz5260's Avatar
Hello guys. I am posting this thread because i did not find a solution to this problem on the internet. My car is jerking when i release the gas. It happens in all gears and in all rpms. First i thought it can be either dv or clutch but it happens below 2-3k rpm and it does not happen when shifting the clutch. Now i am thinking may be the problem is engine mounts but on highway i put the car in neutral and used brakes to test it. There was not any jerking. Drivetrain is also fine. If you know something, please share it with me.
Old Nov 29, 2015, 08:40 PM
Robin651's Avatar
What type of dv do you have? It is re-circ?
Old Nov 30, 2015, 03:07 AM
araz5260's Avatar
No i have an atmospheric dv
Old Dec 1, 2015, 12:20 AM
NHazz's Avatar
Does it eventually go away after a few minutes and do you have aftermarket cams?
Old Dec 1, 2015, 07:30 AM
araz5260's Avatar
Yeah it goes away because of decrease of speed if i do not touch the gas pedal or brake. The cams are stock.
Old Dec 1, 2015, 07:48 AM
NHazz's Avatar
Sounds like the tune man. I was going to say mine does the jerk/buck every once in awhile when the weather goes from one extreme to another. What are your mods?
Old Dec 1, 2015, 08:16 AM
mrbonilla's Avatar
did the issue happened after installing a mod?
Old Dec 1, 2015, 12:03 PM
NHazz's Avatar
The issue for me was very slight, almost to the point of not even being an annoyance. I was told - and don't quote me on this - that cars with aftermarket cams will sometimes do this (mild buck/jerk on partial throttle) until the motor gets to operating temp. The tune definitely will help though. What mods do you have on your car?
Old Dec 6, 2015, 04:04 PM
araz5260's Avatar
The problem was the bov. I changed it to ix mr bov and the jerking went off. Thank you for the reviews
Old Oct 7, 2019, 07:43 PM
Tim Q's Avatar
it's good to hear your issue had been solved. I got simalr issue, jerk/buck when on/off throttle at all gears and any speed. Did yours do the same when at neatual as mine deosnt do this at neatual at all. And what BOV did you use?
TariqEvo
12
Oct 23, 2017 10:31 PM
pjsevo8
Jun 11, 2010 03:07 PM
evo8silver
Feb 9, 2006 02:01 PM
Quick Reply: Car is jerking when releasing the gas pedal
