Suggested maintenance for DD a built engine
Old May 28, 2016, 08:33 AM
EVIL_EV0's Avatar
I recently got a new job and as a result I am now daily driving my built EVO9.
I never expected to put more than a couple hundred track miles on this car and now its seeing about 250 miles per day. I'm most concerned about running the car for 10k miles without balance shafts but honestly I'm also curious if I should entertain a different oil as well. I'm currently running 20w50 Brad Penn and the car is fueled by E85.
Basic parts list include:
Wiseco 9.3:1 forged pistions +.020 over (I do hear some cold engine piston slap)
MAP ultimate duty steel connecting rods
GSC dual valve springs
ACL race series main bearings
ACL thrust washers
ACL race series rod bearings
BBK turbo
I've heard horror stories about the lack of balance shafts causing oil pump failures and vibrations that work bolts loose. Is there anything I can do to proactively prevent a failure? What is the most likely thing to fail? Any advice would be greatly appreciated. Thanks in advance!
Old May 28, 2016, 11:24 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
250 miles a day??? Buy another car. I would not be putting those miles on my EVO.
Old May 28, 2016, 01:24 PM
barneyb's Avatar
Maybe go back to stock motor mounts if you have changed them. That and don't do what is called "California style driving" where you race to the next traffic signal and then watch the sea of brake lights.
EVIL_EV0
May 28, 2016 08:30 AM
dragon831
Jan 14, 2014 03:29 PM
DANERS_03
Sep 7, 2003 10:34 AM
cecilia
26
Jul 19, 2003 06:14 PM
Silencer
Apr 25, 2003 04:05 AM
Quick Reply: Suggested maintenance for DD a built engine
