Mishimoto half rad not cooling
A 12 inch mishimoto fan does not push the same cfm of air as the stock unit. It is advertised around 1200cfm but it actually pushes around 1000 cfm at 2000rpm. Stock unit pushes 2500+ cfm at 2000rpm.
With a half radiator and 35-40 celcius in the summer, assuming you still run an a/c condenser as well, especially in traffic behind exhaust fumes, or under hard and long acceleration on a spirited drive, the 12 inch mishi fan will need to be working constantly to keep the temps at reasonable levels. The control module tends to overheat and damage its circuitry if its constantly on, i.e if you use an ecu unit that keeps it on all the time. Also the unit is added weight when there is actually no need for it.
About the plug, the plug you use now is to mate up with the control unit, when you remove the module, you'll need to use a two piece plug, with one piece attached to the harness and the other attached to the fan wires.
Marios
It sounds like you lost the controller. Last summer I noticed my fan running all of the time. I think always on is a default if the controller fails.
The stock ecu controls the fan module based on the temperature signals it gets from the temp sensor behind the thermostat housing. It turns the module on and off and switches in between high and low speeds. If the module fails partially and does not respond to the ecu's signals to turn off, it stays on, either on high or low speed, until the internal circuitry fails completely and the fan will not kick in at all. The same failure will happen if you intentionally adjust the setting in an ecu to keep the module on , all the time.
Marios
Marios
Evo7 Fan control modules are prone to fail, mostly due to an cold solder inside the module.
Most of the time they start to fail when you remove the big 3pin connector..
After you plug it in again, the trouble starts 2 or 3 weeks later...or instant...
Also the fan runs 8 seconds after engine off until the ecu itself shutting down...or instant on after ignition on with not fully warmed up engine... thats the signs of an broken Fan Controller.
Sometimes the fan will randomly cycle with engine off.
Replace it with an evo 8 / 9 unit, same spec, but Cold solder junction improved...
Here in Germany almost ANY evo 7 fan controller has failed over the years...
Over the years I have seen equally both 7 or 8 modules fail at the same rate. I own an evo 8 i.e, and mine has also failed. I have seen none of the evo 9 ones fail as of yet though.
Marios
Marios
The USDM 2003 and 2004 using the old style module, as well as early Evo 8 RHD and some EDM
The newer design one was introduced in production in September/Oktober 2004
So, in EDM and USD Market these cars come onto the street end of 2004.( Called 2005´s...)
In our cutomer base we had zero Evo8 FAN ECU Fails.....maybe we are lucky...but there was also an service bulletin, so maybe the dealers changed it by default
Yes I do also believe the design of the inner circuit, along with materials used has been updated on a second version of the module as the evo 9 ones have no failures as of yet. I do know that evo 8 in the US was introduced in 2003 as well along with the rest of the world and early 8s carried the same module as evo 7s, I know mine was the evo 7 version and that was part of my point when I said that evo 8 ones also fail, whether that being jdm, edm or usdm.
The other part of the point I wanted to stress comes to contradiction to what you say and to the belief I had up to the point I saw the first 8mr one fail. So it is possible that although two revisions, evo 7 vs evo 8, are apparent, that there was even further improvement on the evo 9 module.
Marios
A
hmm I know switched back to standard fan on the 1/2 rad and again the same thing,
the temperature gauge reads in the middle.
Yet the fan remains always on, it does not cycle on and off.
when I tested the stock fan vs the mishimoto fan outside of the car, the stock fan is way way more powerfull then the slimline mishi.
P.s. what device does one need to get into the ecu of the CT9A and change the temperature level?
Thank you
Thank you
Our winter is usually 25-28 celsius and summer goes up to 42-48 degrees. And so far so good. Although never tested in traffic since it isn't my daily.
Dear all,
I have a baffling issue.
i just installed a half rad from mishi with a 12inch fan from mishi too.
I also fitted a lower temp thermostat and used water wetter as coolant.
The temp gauge stays right in the middle, but the fan does not cut out while car is running.
The temp is 14deg celcius or 57.2deg Fahrenheit currently, however our summers do hit 36deg celcius which is 96deg Fahrenheit.
Im obviously worried that my setup is not able to handle the heat. My car is a 2.4 stroker.
Any ideas?
Thanks!
Any ideas?
Thanks!
I've ran a half size radiator and I see ambient temps of triple digits at high altitude in the summer(which means even less air density). I don't know how well the mishimoto fan actually works but if it doesn't push that many CFM or isn't running at full speed it's not going to work as well.
Also keep in mind the factory gauge isn't very accurate, it can be in the middle and temperatures can fluctuate pretty substantially but still not really change much on the needle. By going to a lower temp thermostat but also going down in radiator size won't necessarily mean the car is going to run super cold. I've found once things are up to temp they aren't going to change much unless your cursing at a fast speed with cold air out. Of course there are other factors that come into play such as fuel type.
1 bottle of water wetter per gallon is too much. not sure if it will degrade the cooling capability, but its way more than necessary for it to do its job.
the job of the water wetter is only as a surfactant to reduce the surface tension of the water so the water can transfer heat better. its still the water doing all the work.
Now in winter you will not have any issues. Depending on how much power you make your cylinder pressures go up. If you run on the lean side of afr as well then this adds to the heat.
For summer :
-Remove water watter, replace with water and antifreeze.
-Remove fan control module, connect the fan straight on to the harness using a plug. Make sure the fan is correctly polarized. The fan will run constantly.
-Upgrade your rad cap to a 1.3bar one.
With the above you'll be able to run your car during the summer heat without any issues.
Marios
For summer :
Marios
Removing the controller may help and the radiator cap won't do anything unless he's having the system boiling off into the overflow.
I'd say if it has these exact symptoms with the stock motor then it can't be anything but the controller. If not, then something else. Simple.
A friend of mine had a broken fan controller, and it would stay on after he switched his car off. And it would randomly go on and off when the car is running.
Also, removing your condenser will allow more air to the radiator. I am running my half rad with the condenser, although I never used the AC since I owned the car for 5-6 years now. Considering removing it.
mishimoto
May 2, 2014 11:51 AM
mblaster890
10
Aug 30, 2012 09:54 PM
B.J.@ToxicFab
12
Mar 11, 2012 04:07 PM
silentkiller
27
Dec 20, 2011 06:22 PM
