T-case
Old Feb 21, 2017, 01:57 PM
Benja258's Avatar
T-case
What exactly jack and shepdo to make the t case stronger at stage 2 or stage3 that can't be done DIY..?
They us oem oring and pinion
Old Feb 21, 2017, 02:25 PM
Received 1,384 Likes on 1,317 Posts
Heres a link to Sheps description of what is done w/the stage II
http://sheptrans.com/product/evo-4-9...ild-stage-2-2/
Old Feb 21, 2017, 03:05 PM
LetsGetThisDone's Avatar
Received 1,542 Likes on 1,321 Posts
You shouldn't send anything to Shep or Jacks. The OEM ring/pinion is stronger than the aftermarket one they offer (not the albins one, but the other one). Contact Team Rip, he will build you a solid tcase.
Old Feb 22, 2017, 06:12 AM
thepoint4life23's Avatar
So whats your saying is you should get a aftermarket Diff and have it put back together.
Old Feb 22, 2017, 08:20 AM
TRE does things you can't do. He machines the case to so they sit square to each other (they aren't perfect from factory), he upgrades the case bolts from 8mm to 10mm, he details and shot peens the gear set, and he sets it up correctly. Mitsu is notorious for having bad setup on the gears, which is a lot of why tcases go bad even in stock cars.
http://teamrip.com/EVO_TRANSFER_CASE_SERVICES.html
Old Feb 24, 2017, 04:13 AM
IzzyRS's Avatar
I wonder if the bolt upgrade is really necessary or was it a solution to someone stripping the 8mm bolt holes and fixing it by going up in size
I will be rebuilding my Tcase with a Wavetrac, but not sure if I should upgrade the case bolts.
Old Feb 24, 2017, 04:19 AM
Benja258's Avatar
the main reason i ask this is that im liveing in israel,i can send it but it will cost like new transfer case.
Old Feb 24, 2017, 11:49 AM
No, it's because the tcase flexes A LOT under load, especially launches. Jon at TRE actually sets the gears up differently in high hp drag only cars to account for this flex in the case, even with the 10mm bolts.
IzzyRS (Feb 24, 2017)
Old Feb 24, 2017, 12:07 PM
IzzyRS's Avatar
Interesting. Good to know.
turboDan
Mar 18, 2008 08:34 PM
Bloomie
Oct 21, 2007 08:14 PM
05evoGSR
Dec 16, 2006 10:57 PM
ct9a gsr
24
Nov 8, 2006 03:35 PM
Quick Reply: T-case
