trans/transfer case oil
Old Jun 20, 2004, 03:17 PM
zmeli's Avatar
I just changed the tranny and transfer case oil. I thought I would let you know what I used since so many post about the wrong fluids being used.
Transmission- Chevron DELO Gear Lubricant ESI 80W-90 GL-4/GL-5/MT-1
does not harm yellow metals.
Transfer case- Castrol Hyploy C Gear oil 80w-90 GL-5 meets Limited slip requirements.
Let my know if this sounds fine. Car is RS version and only has 1965 miles
Thank you.
Old Jun 20, 2004, 03:42 PM
zmeli's Avatar
I did call the dealer first to verify.
The manual calls for:
Manual Transaxle Gear oil API GL-4 SAE 75W-85W or 75W-90.
(My Rs has a front limited slip trans but the Gear oil called out says nothing about any limited slip requirements)
Transfer oil- Hyploid gear oil API classification GL-5 SAE 90.
Strange and a little confusing.
Dealer told me. GL-4 in tranny/ GL-5 in transfer case and rear Diff.
Old Jun 21, 2004, 10:46 AM
patsevo8's Avatar
i just posted a thread.. using regular motor oil (i prefer valvoline 15w30 or40) with just a few ounces of gear lubricant or limited slip oil...I have used this on ALL OF MY CARS (HIGH PERFORMANCE)
Old Jun 21, 2004, 10:49 AM
machron1's Avatar
I just had the dealer swap all my fluids. All 3 gearboxes received Mobil 1 synthetic 75W90, with a $5 bottle of friction modifier in the rear diff. The reason your front diff doesn't have any special requirements is because it is a helical type and does not rely on friction from clutch packs, but simple gears. The mechanic punched up alternative fluids on his computer, and there are a ton.
EDIT: The Mobil1 synthetic is GL-4 and GL-5 compatible. (THIS IS ONLY TRUE FOR AXLES, NOT THE TRANNY!!!)
Old Jun 21, 2004, 03:12 PM
zmeli's Avatar
you better double check the mobil 1 gear oil will attack your brass parts in the tranny. many post on this site about mobil 1 GL-5 gear oil. tranny calls for GL-4
Old Jun 21, 2004, 08:44 PM
matt55's Avatar
Originally Posted by machron1
I just had the dealer swap all my fluids. All 3 gearboxes received Mobil 1 synthetic 75W90, with a $5 bottle of friction modifier in the rear diff. The reason your front diff doesn't have any special requirements is because it is a helical type and does not rely on friction from clutch packs, but simple gears. The mechanic punched up alternative fluids on his computer, and there are a ton. The Mobil1 synthetic is GL-4 and GL-5 compatible.
I tried Mobil 1 in the trans and it SUCKED !!!! Pennzoil Synromeash worked much better in my car
ps..... Mobil 1 sucked in the trans
Old Jun 22, 2004, 11:59 PM
machron1's Avatar
Yep I was just going to say, I keep getting locked out of 2nd now, so I went back & re-read the Mobil1 information again. I thought it said it was approved for GL-4 and GL-5 applications, but here is exactly what it says:
Mobil 1 Synthetic Gear Lubricant LS 75W-140 can also be used in rear axles where API Service GL-4 lubricant is recommended
I didn't notice the REAR AXLE part. I guess that's because there is no brass in the rear axle. I can't believe I listened to the mechanic. He recommended specifically Mobil1 75W90 instead of the stuff he had, which he said was just GL-5 non-synthetic gear oil they use in everything anyway, and that GL-5 was just fine for my transmission. I know I know, there I go again, thinking people can actually do their ****ING JOB once in a while and are not just BULL****ING me either to pretend they know what they are talking about, or don't really care one way or the other...
Old Jun 23, 2004, 05:53 AM
zmeli's Avatar
This was faxed to me from Mitsubishi.
GROUP 22 MANUAL TRANSMISSION
GL-5 and GL-4 Oil Requirements- 2003
Lancer Evolution. Be sure to use the correct fluid when changing the oil on the
Lancer Evolution Transmission, Transfer Case, and Rear Differential. 75-90W or
SAE 90 oil with GL-5 specification is used in the transfer case and rear diferential.
Mitsibishi Diamond Gear Lube 75-85W 0r 75-90W oil with GL-4 specification is used
in the transmission.
CAUTION: Using GL-5 specification oil in the transmission will damage the brass material in the synchronizers. Damage of this nature will not be covered under warranty.
Requirements:
Transmission:
75-85W/75-90W Mitsubishi Diamond Gear Lube, API class GL-4
Capacity: 2.9qt.
Transfer Case & Rear Differential
75-90W or SAE 90LSD or Hypoid Gear Oil, API class GL-5
Capacity .58 qt. for each.
I would go back to dealer and tell them that you lost your receipt and get them to put in writing that they installed the Mobil 1 oil. (before you tell them they made the mistake)
Any tranny issues beyond this point should be blamed on Mitsubishi.
I can fax you a copy if needed.
Old Jun 23, 2004, 03:51 PM
machron1's Avatar
Requirements:
Transmission:
Capacity: 2.9qt.
Thanks but I don't think much damage could have been done in 2 days. I just had them put the normal diamond care 75W85 in there, although the mechanic swears that the Mobil1 has no sulfer and would have been fine if it stayed in there. I forgot to ask the Mobil1 support line whether it really has sulfer in it. He said he also called the service tech line, and they told him as long as the GL5 fluid doesn't have sulpher in it, it should work out dandy. The Mobil1 definitely works in the transfer case and rear diff (along w/ the Mitsubishi friction modifiers) so I left them be.
.[/QUOTE]
Old Jun 23, 2004, 06:44 PM
tpm17's Avatar
Can someone with really high knowledge on this stuff let me know whether or not the stuff I have will or will not work in my car... Also anyone with prior knowledge about these products in ours cars could respond....
I have for the transmission:
BG Syncro Shift For Front Wheel Drive Manual Transmissions Part # 790
Says on the back that it is recommended for vehicles requiring motor oil, ATF or GL-4 gear oil is specified as service fill
For the Transfercase and rear Diff I have:
Red Line Synthetic Oil Heavy Shock Proof Gear Oil
High performance gear lubricant
SAE 75w90
Should I use these products for their respective purposes or should I dump them both?
If I should get rid of them please specify exactly what to buy....
THANK YOU!
Old Jun 24, 2004, 03:04 PM
tpm17's Avatar
Little help anoyone with knowledge about this stuff??
Old Sep 7, 2004, 03:22 PM
titaniumkingpin's Avatar
i want to know also~!
i know for the tranny the pennzoil syncromesh is ok but what about the transfer case and rear diff?
EvoXChii
10
Dec 26, 2012 08:18 AM
adammartini
23
Dec 18, 2009 06:51 AM
pao
Jul 1, 2008 07:00 PM
itsme4g63
34
Mar 3, 2008 02:57 PM
plokivos
17
Mar 28, 2005 10:29 PM
Quick Reply: trans/transfer case oil
