Royal Purple For Transfer Case
Old Aug 16, 2004, 10:29 PM
taylor's Avatar
The only gear oil for the transfer case I've found so far that exactly matches the factory recommended SAE-90 gl-5 is Royal Purple max gear.
The problem is, I've only been able to find it in 5 gallon quantities. Is anyone using this oil, and does anyone know where to get smaller quantities?
Any thoughts on the advantages,if any, of using this over a 75-90 oil?
Old Aug 16, 2004, 11:55 PM
Ferb's Avatar
SAE90 is only sold in 5-gal and 55-gal containers.
Royal Purple is sworn to by a guy i know who races on the pro VW drag circuit. However, their datasheets leave a lot for me to desire, so i don't know if i would be clammoring to get their products.
ferb!
Old Aug 17, 2004, 08:31 PM
Rudy's Avatar
I use Royal Purple Max Gear in my transfer case and no problems at all. I get them in qts from my local speed shop. Try www.dynamicturbo.com
Old Aug 18, 2004, 10:18 AM
taylor's Avatar
ferb!
Thanks for the imput. What, specifically, don't you like about royal purple ?
Old Aug 18, 2004, 10:23 AM
scottatyamaha's Avatar
If it were me I would keep only factory gear lube inthe transfer case and rear diff. you are just asking for problems if you put the wrong kind in and then you will also totally destroy the small chance that you have to get it fixed under warranty. Also alot of the people on here that are blwong transfer cases are using an aftermarket gear lube.....just my 2 cents
Old Aug 18, 2004, 10:30 AM
taylor's Avatar
Thats true, but all the problems I've seen are due to the use of 75-90 oil. Royal purple makes SAE 90 oil which is exactly what mitsu. reccommends.
rgar
Jun 2, 2010 05:50 PM
LANCERGTS2008
Lancer Engine Management / Tuning Forums
96
Nov 30, 2008 09:16 AM
03redtype-s
15
Sep 25, 2008 05:42 PM
Kwman
Mar 16, 2005 03:26 PM
EvilDylan
Mar 10, 2005 08:08 AM
Quick Reply: Royal Purple For Transfer Case
