Evo low beam adjustment question!!..
ok, i am in need of adjusting my HId's higher cuz they are too low, so first i checked the how-to section and found a write up but then i realized it was for the high beams (10mm socket on the bolt thats infront of the 2 gears). so then searched thru discussions regarding that how to and someone stated that the adjustment for the low beams were different. ( https://www.evolutionm.net/forums/sh...0&page=2&pp=15 ). In his picture, he shows the adjustment for hte low beams, its a small plastic thing. U stick a philips in there and turn and it will raise them. When i went out to my car, i saw that there was a metal piece blocking me from putting anything in there to adjust. I looked more in depth in that area and saw that the metal piece was held on by atleast 2 philips screws which are almost impossible to reach. So now what? am i screwed and cant adjust my HIDs on my 03 evo?
in reply to vrooompsh, after reading up on the discussion of that how-to i found out the one with the 10mm with the 2 gears adjusts High beams, i went out and tried it and found it it was true, when i stock a 10mm on there and turned, i noticed my HIDs werent doing crap after 3min of turning nonstop,so i turned on my high beams and 1 of my high beams were way up there.
Originally Posted by Vroompsh
nah what you need to do is get a 10mm socket on the hex head bolt inside the gear wheel. counterclock-wise for up, counterclock-wise for down. just like the writeup says
yea, LOW beams, plz help people, my HIDs feel like regular bulbs cuz theyre so low! no coverage!! the plastic piece that im supposed to stick a philips into has a metal bracket style piece around it and wont allow me to stick anything in there, but in someone's pic theirs didnt ahve the metal piece?/ confused
