ACT Street Disc Clutch Kit??
hey everyone i just wanted to get some reviews on the ACT Street Disc Clutch Kit. how is it for daily driving ( like 80 miles a day )? what are some other stage 1 or 2 clutches i should look into? thanx
i currently have a act and i'm not impressed at all...shift blockage is a nightmare! if i whined out any gear past 7500rpm's it will not let me into the following gate.... period!!!! i've drivin my buddy's with a exedy double plate and it's a dream!!!!! get an exedy.....
hey bro i drive about 80 miles a day to work and school. At the beginning it took me a while to master taking off with this clutch. But now im used to it, it is actually not giving me any problem at all . I actually like the heavier pedal. So far I havent tried shifting past 7000 rpm because I haven't gotten a flash yet so I really don't know about that problem that some ppl are having. I drove 10,000 miles with this clutch already and its still good.
sweet 10,000 miles sounds good to me. but im gonna have to get a flywheel too, cause i have no choice but to drive the evo. even if the clutch slips under normal driving conditions.
I dont have many miles on my ACT clutch, but so far I love it... It's just a bit harder than stock, but for some reason I like it like that.... You wont go wrong with this clutch..
I Have a Stage 2 ACT HDSS, had it about 17-20k miles and it still runs strong. The shifting is abit hard but i have gotten use to it. I never have highRPM Gear lock out wiht this clutch. The ONLY Issue i have is "Clutch Chatter" When your first starting your car, going into reverse at low rpms, or just slightly feathering the gas pedal, the clutch seems to chatter abit, really weird sound but it goes away after about 10 mins of driving. The ACT Clutches are Stout Clutches and stay alive for awhile. Just make sure its adjusted right, or will you get the Infamous "HIGH RPM GEAR LOCK-OUT" Good Luck.
NLTS mod? What's that? Still learning
mine works great never had any problems. everything that can go wrong is just the same as most other single disc clutch that can be fixed with an adjustment. with the proper install and adjustment it should never need to be touched again.
