p0117- need help
Old Mar 5, 2006, 04:14 PM
forbidden color's Avatar
p0117- need help
ok, this time it's my car.
p0117 code is coming up over and over again after I clear it.
Engine Coolant Temperature Circuit Low Input.
I've accidently tapped the wire (yellow pin 83) with a ground wire for the wideband.
Wideband works after we tapped the right ground wire and power source.
Now the car starts up real weak, fan comes up then shuts down.
it's killing me, cause I have no idea how to fix this...
I"m in a different town and the only mechanic in this town is out for a vacation for this whole week.
I can't even have the car start up.
I'm thinking it's something to do with the sensor, but i have no idea...
any help will be great.
Thanks.
Old Mar 5, 2006, 04:24 PM
ttt need some help real fast...
Old Mar 5, 2006, 04:57 PM
anybody????? Evo down! Need a backup!
Old Mar 5, 2006, 05:13 PM
BuLocal's Avatar
Have you tried disconecting your battery or clearing the code? May not be that simple but either way here's a bump for the cause.
Old Mar 5, 2006, 05:38 PM
yeh, i've cleared it with my code clearer (orange thing) and then after that i've hard reset it by disconnecting the battery and leaving it for 30 minutes, then replug.
Now the car runs, but it's running lean when the foot is off the throttle. Then it tries to shut itself down.
Also the fan is constantly on!
I'm thinking it maybe the coolant temperature sensor... I don't even know where that is.
So I'm gonna go do some research but I need some help on this topic, if anyone has done this or went through this...
Thanks...
So far, online searching came to 0 conclusion, since it's not something that happens often...
Old Mar 5, 2006, 06:04 PM
the wire isn't disconnected or anything. I used the t-connector and just the side rubber housing is opened up...
Old Mar 5, 2006, 06:47 PM
bump on any insight...
Old Mar 5, 2006, 06:57 PM
TTP Engineering's Avatar
Check the coolant temp sensor plug at the tstat.
Old Mar 5, 2006, 07:33 PM
what would happen if i drove my car for about an hour and a half with this cel light on and fan running? do you think it would cause any serious problems?
also does anyone know how much that sensor is?
thanks so much for the help guys.
Old Mar 6, 2006, 08:43 AM
coolant temp sensor plug.
Where is that located? I know you follow the top radiator line all the way to the firewall, but I just can't seem to find it...
Old Mar 6, 2006, 08:48 AM
8urv8's Avatar
I had something similar with my 04 Mustang. Every time I would start the car, the cooling fan would come on, and just run while the car was on. Only difference was the the car started fine and ran fine. It was still driveable. Any way, the temperature sensor was unplugged. I had unplugged it because the harness was in the way of something else I was working on, and I just forgot to plug it back in. I don't know the exact location of it on the Evo. Check it out, who knows, it might be your issue.
Old Mar 6, 2006, 09:10 AM
Well, i haven't really touched that sensor or anything in the engine bay, except for the spark plugs I've change earlier that day.
I might of really just fried that sensor.
Coolant temperature sensor probably needs to be replaced...
Anyone know where this sensor is?????
Old Mar 6, 2006, 09:32 AM
Under the cam angle sensor. I figure your next post is "where is the cam angle sensor" though.
Follow the upper radiator line toward the tstat housing and it will be underneith.
Old Mar 6, 2006, 09:41 AM
right on.
I know where cam angle sensor is though. :P
picture will be great though. I'm more of a visual person than anything.
Old Mar 6, 2006, 10:04 AM
Originally Posted by forbidden color
right on.
Quick Reply: p0117- need help
