evo specific grounding kit for cheap? (yes, I searched)
Old Jun 15, 2006, 07:01 AM
blacksheep's Avatar
Yes, I did search - I found a lot of info on grounding kits (HKS, buddy cub etc) , but they are a lot of money for what they are.
I also found generic kits for cheap, but read of quality issues, non-soldered wires, cheap ring terminals etc....
So, is there a compromise - good quality and cheap? Does it come with directions on install and which grounding points to use?
Or do I make my own? I was going to use a distribution block and run 4 gauge to it and the others off the distibution block?
I found the two attached pics for grounding points - if someone has more to add, that would be great!
Also, there are 2 styles: One is seperate wires while the other is like one long wire (as pictured below) Any difference between the two?
Please let me know!
Thanks!
Attached Thumbnails evo specific grounding kit for cheap? (yes, I searched)-ground-wire-instruction.jpg   evo specific grounding kit for cheap? (yes, I searched)-groundkit.jpg
Old Jun 15, 2006, 07:04 AM
EvoDan2004's Avatar
id rather have a nice kit then something that looks like spageti
Old Jun 15, 2006, 07:06 AM
blacksheep's Avatar
So, you are saying: buy an expensive kit? They all look the same - wires to different points in the bay, right?
Old Jun 15, 2006, 07:11 AM
aklucsarits's Avatar
You could just as easily build your own "grounding kit" for $10 or less with parts from the electrical/wiring dept at you local Home Depot or Lowes.
Old Jun 15, 2006, 09:02 AM
Lancer EVO IX's Avatar
I have the Sun Auto Cyber Speed Hyper Grounding Kit and Hyper Voltage kit. They are specifically designed for the EVO and have specific grounding points. However, it is not cheap. I noticed an improved idle, brighter headlights, slightly better torque, and better throttle response. It is used on the record breaking Cyber EVO.
http://www.sunautomobile.com/product...eed.htm#ground
Old Jun 15, 2006, 02:33 PM
sonicnofadz's Avatar
Just make your own. The thicker the wire the better. Its just a ground for christ's sake.
Old Jun 15, 2006, 05:44 PM
hk2ronin's Avatar
I have the lineage grounding kit. Thick wires, platinum ends, crimped not soldered, I think 7 different colors. I got it for 60 dollars from vivid racing. Lineage.com has em for 60 dollars to.For the price you can't beat the quality-I was very impressed with the kit and would recomend it to anyone looking for a alternative to the bigger name brand ones.
Old Jun 15, 2006, 06:29 PM
first5.0's Avatar
i have a bridge in new york that i'll sell to you for cheap. it's already grounded, too.
Old Jun 15, 2006, 11:46 PM
WynnS123's Avatar
how much do you want for the bridge?
Old Jun 15, 2006, 11:47 PM
WynnS123's Avatar
Make your own kit. Save some$$$
Old Jun 16, 2006, 01:35 AM
RenoEvo's Avatar
grounding kits are useless besides slightly better voltage. LMAO @ the "increased torque" comment!
Old Jun 16, 2006, 05:06 AM
mump's Avatar
I also have both of the kits from Cyber Speed. First I had the Voltage kit with a cheap DIY kit. I was so impressed by the voltage kit, I thought "damn if this is this good then the Grounding Kit got to be impressive too. - Nope. I didn't notice anything. But I give a to the Voltage kit.
bustin
Mar 18, 2018 05:44 PM
Walkingchaos
Jan 4, 2006 09:21 AM
Shingen
Mar 25, 2005 05:47 AM
Iamkar33m
Lancer Engine Tech
14
Oct 29, 2004 12:11 PM
ambystom01
Oct 12, 2004 09:38 PM
Quick Reply: evo specific grounding kit for cheap? (yes, I searched)
