$5 o2 non fouler problem
i put on my invidia tbe on about 3 weeks ago with no cat and no resonator and used the $5 o2 fix methed with the non foulers.did everything right and everything seems to be fine and just today i got a CEL.some say that the non foulers only work on about half of the cars tried but i do a lot of driving.sometimes like 130 miles a day.i just dont understand would it really take that long to come on?
did you use the short or long o2 non foulers? i used one long one on my g/f's evo and it worked hasn't turned back on. did you check what CEL code came on? it might be something else or the fouler might have come loose
i did use 2. i did everything it said. drilled the one out and everything.but they both were the same size and not that big. any suggestions?
Location: Michigan, Indiana, depends on the time of day.
find out what code was thrown, then reset your ECU And see if it comes back. if it doesnt you're fine and it might have been a quirk. if it does then i'd try checking your fittings, make sure they're tight and if worse comes to worse buy a longer fouler.
