Rod Knock??
Rod Knock??
How can you tell the difference between a slight rod knock and just normal engine noise?
I may be just paranoid, but is there some way to tell?
The car only has a TBE, and seems to drive fine.
Thanks!
Thanks!
Former Vendor
What exactly are you hearing? The only thing I could think of is lifter noise. It's a stock block so it can't be piston slap. A rod knock would be pretty damn loud. How many miles you have on it?
have you checked oil? low oil can cause some tapping in the valvetrain. also, next time you drain it, you can buy a cone with a screen to let the oil drain through. if you're getting rod knock, more than likely, you'll have metal shavings from bearing material in the oil. that's something you could check to troubleshoot.
Former Vendor
Shouldn't be hearing any kinda knock. You using 93 octane? I know certain fuels can make a pinging noise. Kinda hard to trouble shoot it without hearing the noise. The mileage is low to be having any rod failure unless you beat the **** outa your car. When you hear the noise, does it match the rpms? What I mean is does it knock faster as you give it gas?
Former Vendor
All I can say is take it to someone to check it out(someone you trust of course, don't want them to tell you it's the muffler bearings). Did you buy it used? I got mine used and the dealer put it back to stock. When they put the stock cams back in they didn't bleed the lifters, now, I got all kindsa noise from the motor.
