Carbon fiber e-brake handle install??
Old Dec 28, 2007, 07:05 AM
Forrest Gump 9's Avatar
I've just got a set of OEM pedal inserts and the CF ebrake handle as a X-mas present. I just can't see how the CF ebrake handle can be fit over the stocker? Do I have to cut the stock plastic handle to make it fit? Please help me find some info on how to install this.
For some reasons, it come with 1 sheet of instruction from the factory. Only said what tools and precaution but no actual steps of how to. Thanks in advance
Old Dec 28, 2007, 09:11 AM
Plat Vendor
RussellM's Avatar
I tried digging up a .pdf of the instructions, but Mitsubishi doesnt have anything in their database on it. I know a lot of the accessories that they deem "easy" to install dont come with very good instructions. Hopefully someone else here has done it and can answer your question.
Old Dec 28, 2007, 09:17 AM
jenx1976's Avatar
you need to take the stock one off., no need to cut...,just get a hair dryer., heat it up a bit (warm to the touch) twist and pull. it should come right off. worked on mine. (stock leather handle)
Old Dec 28, 2007, 03:11 PM
Mine is a RS. It is a plastic piece and it goes all the way down into the center console. So do I have to take that whole piece out? Thanks for answer.
Old Dec 28, 2007, 03:21 PM
twentyone's Avatar
For the RS, yes you have to remove the whole piece. You may need to buy an entire handbrake assembly that comes from the GSR to use your ebrake handle (if what you bought is only the handle).
CaptainCrunch
Jun 23, 2016 08:16 PM
logicalfaith
Mar 11, 2015 12:13 PM
mx4life85
Oct 11, 2014 08:59 AM
sanjaya1
Jun 20, 2013 09:46 PM
CF03MR
Aug 30, 2012 01:48 PM
Quick Reply: Carbon fiber e-brake handle install??
