Scheduled Maintenance Tables & Fluid Part #'s/Quantities
Old Jan 18, 2014, 10:46 AM
  #136
treager's Avatar
Hi! may I ask what are the things you need to change and check(maintenance parts)when I bought an 80,000odo evo 7, I dont really know where to start and how to make it in a good condition! Thank you very much!.
Had it changed oil already and bought a new spark plug! but I think the space and right adjustments for the spark plugs are wrong
Old Feb 26, 2014, 01:18 PM
  #137
05SilverBullet's Avatar
i gapped my plugs to .24 with one step colder ngk bpr8es.
Old May 29, 2014, 06:25 PM
  #138
mchristian's Avatar
I've book marked this thread and refer back to it every few months! Can we get the first page updated with the newest Mitsu part numbers and photos for reference?
Old Jun 16, 2014, 08:48 AM
  #139
edgeofautumn9's Avatar
Bump for Useful Info
Old Aug 21, 2014, 07:53 AM
  #140
bagwe11's Avatar
Great info
Old Jan 5, 2016, 08:00 AM
  #141
tmaddox's Avatar
I just bought some OEM PSF for my 2005 Evo VIII from Mitsubishiparts.net. It came in a 1 liter (34 ounce) metal can, with both Japanese and English writing. It was labeled DiaQueen PSF part 4039645. Is that a new number to replace the number ACH1ZC1X04 you have listed at the start of this thread?
Old Aug 17, 2016, 04:15 PM
  #142
wcassar's Avatar
evo 3 oil
Hi I need the oem oil recommands for the evo3 Transmission....transfer case and rear lsd differetial...any help please ?
Old Aug 17, 2016, 06:20 PM
  #143
Received 1,384 Likes on 1,317 Posts
If you dont get an answer here you should post/join the MLR forum. Many early model EVOs there
Link is in my sig. See Best EVO Build
Old Oct 7, 2016, 05:15 PM
  #144
Trailmix28's Avatar
Redline cocktail for tranny!
Old Mar 29, 2017, 09:09 AM
  #145
PasielakL's Avatar
How big of a difference in price of maintenance would it make if you did it yourself or charged someone else to do it for you. I know some of the maintenance that you have to do are a little difficult but YouTube is your friend and I have the tools for it. I also have a friend with an Evo that can help me with it.
Old Jun 9, 2017, 11:50 AM
  #146
7rrivera7's Avatar
Is this the fluid I need after repairing or replacing the ACD pump on my 2006 EVO 9?
ACD Operating Fluid
- Diamond ATF SP III - ACH1ZC1X05 (1 qt)
- capacity 0.95 qts
Old Jun 9, 2017, 12:12 PM
  #147
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Yes, or any other compatible ATF.
Old Jun 9, 2017, 01:32 PM
  #148
7rrivera7's Avatar
Is a quart enough? Is the bleeding procedure documented within this forum?
Thanks!
Old Jun 9, 2017, 03:02 PM
  #149
Quart is enough. Use a vacuum bleeder to pull fluid through the bleeder.
Old Jun 10, 2017, 05:05 AM
  #150
7rrivera7's Avatar
Do you know which are actually 100% compatible? Searching has not given me a definitive answer...
Quick Reply: Scheduled Maintenance Tables & Fluid Part #'s/Quantities
