Metal scraping
Metal scraping
about 2 weeks ago i was driving and suddenly heard a loud metal on metal scraping/crushing noise coming from my car
its been happening when i slow down or go into corners at slow speeds
it sounds like its coming from a wheel area
also when i purchased my car i had a loud noise coming from the back at high speeds like a wooooooooow-wooooooooow noise does any one else get this?
i dismissed it because it never affected performance and i always heard evo' were noisy as hell
help plz
help plz
I'd say the wooooooooow wooooooooow noise is to do with the wheel baring. But as for the metal scraping sound......
I had this on my evo 9 when I would slow down or enter a corner, it didnt do it everytime, so was a random noise, but was quite frequent. What it turned out to be was one of the sway bars touching the exhaust under the car, i believe it was the 2nd back from the front. It had a gap of around half centimeter when I fit the exhaust and when the car was stationary, but under load the engine twists etc, and they would come into contact under certain conditions. I just put a small spacer to lower the sway bar another half centimeter and Ive never had any problems since. give this a serious look as its a simple fix to a very annoying problem
i'll check sway bar thing 2morrow morning thanks alot for the help
btw did your sound happen right when you installed the exhaust
I had a "bong" (not the kind you smoke from) type noise, like the sound of someone hitting the spring with a rubber mallet, coming from the front when under similar conditions. Turned out to be the bearings in the upper strut mount.
Another thing I have found, if you drive your car in winter conditions where they use cinders on the road. Sometimes they will collect on the springs and get caught in between two coils where the dead coils start.. (I have aftermarket springs) When the suspension compresses you can hear the cinders being crushed. That makes a lovely sound.
eddy5201314
Jan 8, 2017 10:12 PM
