Need help smoke comming out of vents when the heater was on
Old Mar 14, 2009, 10:46 AM
ktk
ktk's Avatar
Originally Posted by SmikeEvo
Ah storage - a rodent could have climbed up into your car and made a home in the wiring/chewed on them. They are attracted to the electric hum.
Check fuses, but my guess is something ate wires. When you turned on the fan, the exposed wiring touched something and fried it (smoked). Thats why the fans worked then. But now since the wires have fried - nothing works. Or the outside chance a fuse popped - saving a fire.
You might want to go to a audio shop or dealer. They can check all the wiring to see where it is messed up.
ktk and I share the worried on an electrical fire. I have seen cars go up from them.
Ah yes, this explanation makes the most sense so far given your symptoms! Good call SmikeEvo.
Old Mar 14, 2009, 10:49 AM
W_evo8's Avatar
the blower motor was shorted out from water leaking from the air conditioning
Old Mar 14, 2009, 12:51 PM
Epix_'s Avatar
Good, easy fix. Next time try to be more specific and the cause can be narrowed down quicker. Diagnosing over the internet doesn't work unless you have every single detail.
Old Mar 14, 2009, 01:43 PM
DocCola's Avatar
sounds like when my heater stopped working after I drove my car the first time getting home from Iraq. It was in storage and my heat worked for like 2 hours. Thank god mistu actually fixed it under warrenty.
Old Mar 15, 2009, 06:52 AM
barneyb's Avatar
The only things in the heater box I can think of are the blower itself and maybe a resistor block. So, yeah, take it to the dealer. If they have a problem fixing this then you know you don't want them tackling any real problems.
Old Mar 15, 2009, 07:02 AM
W_evo8's Avatar
I will never bring my car to a dealership.
Old Mar 15, 2009, 11:17 AM
EvoJoe21's Avatar
same thing happened in my GTI and i had to replace the heater core. and as far as labor...the ripped my whole dash out
Old Mar 15, 2009, 12:02 PM
EvoJoeIX's Avatar
if you have your warranty just take it to a dealer
as long as its not a rodent that crawled up in there and caused it, it will be fixed under warranty.
if its a heater core, that is a lot of work to do and heater cores are not cheap. but if your that afraid of taking your car to a dealer and would rather throw away money doing it yourself, good luck
Evo_Goodness
Nov 29, 2016 05:47 AM
hearnoevo
Dec 2, 2015 09:12 AM
foxracingx25
Jul 29, 2010 10:28 PM
CaptainBoosT
Jun 23, 2010 04:54 PM
JerseyEvo
23
Dec 23, 2006 10:01 PM
Quick Reply: Need help smoke comming out of vents when the heater was on
