bouncing steering column
First i apologize if their is another thread out their covering this topic but i have searched and searched and the closest thing i could find is shaking steering wheels... But here is my problem, i don't experience any problem with my steering column until i go about 100+ and then my steering column slowly starts bouncing up and down until it is extremely violent at around 130-140 and its not like a shaking but literally bouncing up then down about a few inches each way... now i usually don't like going that fast but it just doesn't seem right for that to happen. does anyone have any incite to what the problem could be, and how to fix it?
is your steering wheel tilt thing locked?
sounds scary... you probably dont want to drive that fast until its fixed... if it breaks going that fast and you loose control of your steering your probably not going to live
Yes it is locked completely, and i went that speed once and and after that was to scared to do it again till i found out what was causing it and how to fix it. like u said i didnt want to have something go wrong with the steering and wipe out going 140...
i understand that, that's why i said i don't like to go that fast. but i don't think you can find to may people with an evo that can say they haven't tested the potential of their car outside the track. i really don't want to be criticized for driving fast i just wanted to see if anyone can help me out with this problem. i understand its not a good idea to do and don't recommend people to do it.
wow, well can you move it up and down by hand? i would remove the column cover and make sure its all bolted up still. im not sure on the evo, but usually theres just 2 or 4 bolts holding the column to the dash frame. also maybe there is a problem with alignment or wheel balance.
gallas,
I went that fast a few times and had no problems. Also realize that when you are going that fast any tiny little bump is going to be like hitting a speed bump. The whole car is most likely shaking and you are getting air off of any irregularity in the road. This is the whole reason going so fast is not a good idea. Well other then you are far beyond terminal volicty for a car crash. Also what was your RPM's at? You should be getting pretty high for a stock evo at that speed.
gallas,
Yes a good analogy would be a cd. If you take a music cd and put a little piece of tape on one side you could spin it all you want manually and not notice a difference. But when you put it in a cd player it will bounce all over the place. If I remembered any physics i'd try to explain it to you .
