Car won't start right away..pls help.
My truck used to do the same thing. The started was going out, and it would grind the flywheel because it would not shoot out far enough.
Over time it got worse, and started hitting the flywheel in one "click" sound, since it did not shoot out far enough.
Easy deal, take it out and have it tested, napa, shucks, all these places test for free, if its not that, it could be just a bad flywheel.
They are designed to line up, sometimes, the ring is not one EXACTLY where it is suppose to be, which would give you you're symptoms also.
But the started first, easier to take out than the flywheel.
