A/C problem???
Old May 2, 2010, 05:32 PM
t8sevo8's Avatar
A/C problem???
i have noticed that when i run my a/c that there is smoke coming from under the hood on the passenger side...it doesnt have a particular smell or nething and if i turn the a/c off it stops...i was wondering if neone has had this problem and wat it could be...maybe just condensation hitting a hot part of the motor and causing steam?....ne help would be greatly appreciated
Thanks
Old May 3, 2010, 06:47 AM
barneyb's Avatar
Uh, I'd suggest operating the A/C with the hood open so you can watch.
Old May 3, 2010, 09:27 AM
Berts24's Avatar
^ this, it's most likely your compressor clutch
Old May 3, 2010, 01:37 PM
t8sevo8's Avatar
ok ill try that and i was also told if it was the clutch it would smell like burnt electronics?(is this correct) bc it doesnt have a particular smell...
Old May 11, 2010, 11:09 AM
bizaarhatch's Avatar
Check and see how tight ur belts are also....
NOT WITH THE CAR RUNNING!!!
Old May 11, 2010, 04:50 PM
WHA DAT's Avatar
Old May 11, 2010, 06:25 PM
dreyfus14's Avatar
If it was the belts they would be squeeling....its not condensation hitting anything either.... it is the either the compressor front seal leaking only when the clutch is engaged, but that is usually only a slow leak.....or you could have a restriction in the system causing the high pressure relief valve to relieve freon from the compressor to save it from failure. HIGH PRESSURE RELIEF VALVE- A valve similar to a fuse in an electrical circuit. If air conditioning controls normally used to limit high side pressure fail, and pressure reaches dangerously high levels, the relief valve will open and release the excess pressure to the atmosphere. Basically if freon is shooting out the back/side of the compressor, your high pressure switch has failed either not cutting on the other fan or cutting out the compressor when the pressure gets high...so the relief valve opens up to prevent catastrophic failure to your a/c system. The compressor will eventually stop working due to the low side pressure switch not letting it work due to it sensing low pressure from losing all the freon after this happening enough times. If you could tell us where it is leaking from, I can help you diagnose it better.
Ibrahim Nabil
May 5, 2015 08:18 AM
kingjhay723
12
Mar 23, 2014 07:13 PM
ralliart 04 21
Jul 29, 2013 11:36 AM
Bibi_is_hername
Jul 21, 2011 02:45 PM
PR_DSM
AEM EMS
Jul 18, 2010 08:28 AM
Quick Reply: A/C problem???
