Hesitation/Breakup above 3000rpm
I have recently been having an issue where the car begins to hesitate/break up above 3000rpm's. It occurs in both boost and vac. I can build boost no problem before 3000rpm but as soon as I pass 3-3.5k the car begins to violently break up. The car was working great a few days ago. I am currently running a 2.3L stroker on e85 with an aem c2di ignition system and aem ems. I recently changed spark plugs and I have already tried gapping them a 0.020 and at 0.028 and the problem persists. I am wondering if this is an ignition related problem? Any help/ideas would be greatly appreciated. Thanks.
EDIT:: Car works great again. Thanks for all the help guys. The problem was the Camshaft Position sensor.
Hrmm i will definitely look into that. The only reason I haven't checked that yet is because I can build like 18psi before 3k but as soon as I pass 3k it cuts out on me. My a/f ratio looks pretty normal under wot though on the uego. I am on a speed density setup btw.
I am on aem ems so the cel doesn't work. The e85 tune I am on right now is pretty conservative but I have no idea what % ethanol is in the fuel right now. I guess I will run through this tank and load the 91 tune and some 91 and see if the problem goes away.
Thank you for all the ideas guys. I checked the Fuel pump and filter since it seemed probably that either was clogged/broken and they appeared to be fine. I then picked up a new camshaft position sensor and it solved the problem I appreciate all the responses I received here.
khaled_hourani
15
Apr 24, 2017 04:10 AM
Blu_SmUrF
10
Feb 25, 2015 02:57 PM
