Service Engine Soon Light coming on and off...
Old Dec 21, 2010, 07:32 AM
d4vid's Avatar
Hello,
California has been getting crazy rain and my SES light is going on and off... It was on for a day and next day it was off.... and now its back again.. I would go pull the codes but due to busy work schedule can't seem to find a time to make a trip to pep boys...
I was just wondering if any of you had this problem and if so how did you fix it? I know I can reset the SES light by disconnecting the battery but curious whats cusing the light to come on....
Old Dec 21, 2010, 07:38 AM
Tribal's Avatar
knock cel maybe?, what were you doing that cause the light to come on. does she boost with no issues?
Old Dec 21, 2010, 07:40 AM
d4vid's Avatar
Originally Posted by Tribal
knock cel maybe?
Sorry but whats knock cel???
Old Dec 21, 2010, 08:08 AM
trialsindude's Avatar
If you are boosting and you get a knock from your engine your cel will flash.
Old Dec 21, 2010, 08:11 AM
ODUB's Avatar
that doesn't happen automatically. you've got to program that in ECUflash. if he was knocking he'd have a lot more happening than just a light. car would be losing power due to pulling timing to combat the knock.
Old Dec 21, 2010, 08:12 AM
Gator8's Avatar
your car is having sporadic migraines.... jk, does it only do it in the rain? have you had it tuned?
Old Dec 21, 2010, 08:23 AM
Gator8's Avatar
what all has been done to the car? start from most recent mods.
Old Dec 21, 2010, 08:29 AM
TeStUdO's Avatar
Be sure to check under the cowl and make sure this isn't your problem:
https://www.evolutionm.net/forums/ev...-warrenty.html
You mentioned it's raining a lot, so it's a possibility.
Old Dec 21, 2010, 08:32 AM
Gator8's Avatar
thats what i was thinking on the rain also...
Old Dec 21, 2010, 11:13 AM
d4vid's Avatar
Nothing much done to the engine.. just MEP ported exhaust mainfolds..
Old Dec 21, 2010, 11:15 AM
d4vid's Avatar
Thanks.. I'll check it out!
Old Dec 21, 2010, 01:27 PM
escodotcarter's Avatar
do you still have the factory undertray on? if not then it might be the water splashing up on certain sensors........it happend to me on my old car (03 lancer es).
Old Dec 21, 2010, 09:33 PM
d4vid's Avatar
That is CORRECT!! While getting some suspension work done at RRE, they ran the code.. it had to do with CAT being cold and not working properly.. due to massive rain and water ... anyways thanks guys!
Old Dec 22, 2010, 09:51 AM
d4vid's Avatar
Maybe i should put the tray back on?? did all of you remove the tray???
Old Dec 22, 2010, 11:15 AM
TeStUdO's Avatar
Most people have removed it. Removing the plastic undertray won't cause you to throw a code for the cat. I bet you have an exhaust leak, have a dying O2 sensor or cat, or have exposed wires on your O2. What is the exact code you were throwing?
Quick Reply: Service Engine Soon Light coming on and off...
