White smoke on cold start
Old Apr 6, 2011, 03:45 PM
jtbell86's Avatar
Before anyone says anything, yes I did search and every one elses symptoms seem to be a bit different. Anyway all winter on cold starts I would get some white smoke from exhaust but just thought this was because it was -40 outside. Lately we have been having nicer warm days and I have noticed a decent amount of white smoke at start up. It goes away once the car is warm and I have not noticed any at wot or even while driving. On decel now and again I do get a bit of an exhaust smell but I think thats just me running a bit rich.
I doubt its a headgasket because I have had a blown HG before and know the coolant smell / burning of coolant which I dont seem to be getting.
My thought as of now is condensation in the exhaust which is just burning off when I start the car, but I could be wrong.
Anyone have this problem? Advice would be helpful. Thanks in advance.
Old Apr 6, 2011, 05:40 PM
EvoDom's Avatar
If your getting white/bluish smoke on start up only more than likely it's valve seals. Oil will leak down past the seals and get blown out on start up and then clear up once the engine is warm.
I had this problem on one of my cobras in the past.
Old Apr 6, 2011, 05:42 PM
brenner's Avatar
+1 on valveseals.
or if you have a catchcan, check to see if the lines are frozen.
Old Apr 6, 2011, 05:49 PM
jtbell86's Avatar
what kind of dangers do I run with running it the way it is for the time being. Im moving to Germany soon and really dont want to spend a bunch of money that I've been saving for the move.
Old Apr 6, 2011, 05:52 PM
EvoDom's Avatar
It won't really be to much damage to run it the way it is, if it is valve seals. Most it should do is foul some plugs if it's really bad.
Old Apr 6, 2011, 05:54 PM
jtbell86's Avatar
Awsome, thank you very much! im going to check my plugs now and see how trashed they are.
Old Apr 6, 2011, 07:58 PM
EvoDom's Avatar
Np glad I could help
Dom
Old Apr 6, 2011, 10:01 PM
barneyb's Avatar
Leaky valve seals will gradually consume your oil so keep checking your oil level.
Old Jan 17, 2016, 04:54 PM
Illumin8's Avatar
Originally Posted by brenner
+1 on valveseals.
You know, I just had this issue when my car was out over night outside with 0 degree weather. Usually always garage kept. I installed a catch can this summer so I never experienced a frozen catch can line before. So you are saying that if the line freezes to the catch can that this can produce a lot of white exhaust smoke that goes away once the car warms up? Once I drove the car around, eventually the this white exhaust smoke went away. But boy was it a good amount and I was concerned. I looked at my oil and coolant levels and they seemed good. Not indicating either one burning away. So now I am thinking that my catch can line was frozen since you brought this up. I honestly thought someone pumped something into my exhaust and it was burning it away.
evo9gtx (May 8, 2016)
Old May 9, 2016, 12:01 AM
evo9gtx's Avatar
Now when you say the lines froze up on you how did you figure did you remove the lines and notice an issue with one of them and did u replace them and did that fix your problem? I noticed mine would only blow white smoke whenever I start the car but driving it it doesn't smoke out of the exhaust at all.
Old May 9, 2016, 06:43 AM
GTijoejoe's Avatar
I had a similar issue with a different car and it was my HG.. leaking a small amount of oil in a cylinder. When it heated up it went away.
Just FYI
onlynamenotused
15
Oct 13, 2018 11:48 AM
Scottr126
Jan 21, 2018 01:04 PM
Bmurray
190
Sep 20, 2017 06:01 PM
Hoojan
Jul 21, 2016 08:36 AM
changocox1322
Feb 24, 2016 07:09 PM
Quick Reply: White smoke on cold start
