ACD problem
ACD problem
Just took the car to the dealer today to bleed the ACD since all 3 lights lit up. The mechanic said the ACD is not communicating with the scan tool so he had to do a manual bleed. After I left, all 3 lights went on again. Any idea what could cause this?
I noticed the ACD only acting up in hot and humid weather. When it's raining or cold outside, it works like it supposed to.
Update: Did the paperclip in the OBD trick and got code 82.
I need a used but working pump. PM me if you have one.
So I just went out and turn the car on (not start the car), give it gas and the pump turn on for 10 sec then all 3 lights went on (it didn't do this before).
Is there any way to read the error code beside the scan tool at dealership? They tried to plug it in but it won't communicate (mechanic says they'll have to check the wiring and that could take hrs).
took this from another post
hi i will try to help out, 3 acd lights means there is a fault with the acd or the abs, fault codes are stored in the acd ecu,
get a paper clip and use it to bridge pins 1&4 on your obd
(diagnostics plug) as you sit in the driver seat its in front of your right knee,
when the paper clip is in place turn the key on (dont start the car)
if there are no faults codes the 3 acd lights will flash rapidly.
and if there is fault codes, the 3 lights will flash slower
for example fault code 65
there will be 6 long flashes slight pause followed by 5 short flashes,
simply count the long flashes as 10 6x10
and the short flashes as 1 5x1 = 65
there may be more than one code.
Quote:
here are the acd/abs fault codes
12 power supply open or short circuit
21 fr right wheel speed sensor open or short circuit
22 fr left wheel speed sensor open or short circuit
23 rear right wheel speed sensor open or short circuit
24 rear left wheel speed sensor open or short circuit
25 wrong diam tyre
26 faulty wheel speed sensor
31 steer sensor system(st1,st2,stn)open circuit
32 steer sensor stn short circuit
33 steer sensor stn system
34 steer system st1 st2 short circuit
41 tps open or short circuit
51 longitudinal acc sensor open or short circuit
52 longitudinal acc sensor
56 lateral acc sensor open or short circuit
61 stop lamp switch system open-circuit
65 abs monitor system open or short circuit
71 proportioning valve system open or short circuit
72 directional control valve right open or short circuit
73 directional control valve left open or short circuit
81 ayc relay system open or short circuit
82 electric pump system
83 electric pump system
25 wrong diam tyre
25 wrong diam tyre
25 wrong diam tyre
Care to explain more about the FWD thing? When the ACD malfuntion, the rear wheels doesn't get power???
And the most important question is: Is it ok to keep driving until I replace the pump? Would it damage the TC?
