throttle hang issue. need help
Old Aug 1, 2011, 09:34 AM
boosted91t's Avatar
I sent you 2 maps, try them out and report back!
Old Aug 1, 2011, 09:35 AM
geevolution's Avatar
I'm just as stumped as you are now lol, upload a few logs someone should be able to figure it out for you
Old Aug 1, 2011, 09:54 AM
_______'s Avatar
Subscribed. I have this issue with my ix and my buddy had this with his ix. Both are mrs
Old Aug 1, 2011, 09:59 AM
EvoJoeIX's Avatar
i just put the 1st map in. ill report back when im home from work tonight
Old Aug 1, 2011, 10:21 AM
metalsaber's Avatar
Are you on stock throttle body or aftermarket?
Old Aug 1, 2011, 10:32 AM
EvoJoeIX's Avatar
im on a 65mm mil-spec
Old Aug 1, 2011, 10:47 AM
metalsaber's Avatar
I had trouble with my Aftermarket one as well. The flap isn't completely closed.
Couple things to test. If it does this again, put car in neutral with handbrake on. Open hood. on the THrottle Cable return spring (on throttle body), attempt to pull back the spring a little (attempting to close it). On mine it didn't feel like it moved, but the idle would fall back to normal.
The other thing to try is when it revs high, slowly release the clutch (no gas). Just before it stalls, push clutch in. This one is a little trickier.
If either one of these methods works, it's possible your throttle body needs fixed.
Old Aug 1, 2011, 11:00 AM
EvoJoeIX's Avatar
i have tried this before and it doesnt change anything.
i was thinking TB also, but if it was the TB wouldnt these problems always be there? sometimes the car acts up and other times its fine. i dont get it
Old Aug 1, 2011, 11:10 AM
eric06ix's Avatar
I have a similar issue where the rpms don't seem to drop as quickly sometimes when I let off the throttle. An example of this is slowing for a stop. Sometimes, the brakes feel like they are fighting the engine and it takes a second or two for the revs to drop. My car is stock TB, stock tune. I tried cleaning the TB with carb cleaner and a rag, but haven't watched the TPS through EvoScan.
Old Aug 1, 2011, 12:40 PM
EvoJoeIX's Avatar
Well i drove to work on the 1st map i was sent. The drive is about 10 miles but the car does not throttle hang anymore. Huge difference. I will drive more and see if it acts up any and let you guys know. Huge thanks to boosted91t
Old Aug 2, 2011, 03:27 PM
MechTech's Avatar
Boosted, u mind telling what you changed to get it to idle down?
Old Apr 28, 2013, 04:00 PM
evobros's Avatar
So this was an ecu problem?? I was about to buy a tb because I thought my tb was going to need a rebuild.
Old Apr 28, 2013, 04:20 PM
EvoJoeIX's Avatar
Yes this was an ecu issue, not TB
Old Feb 26, 2014, 08:12 AM
aggieEVO's Avatar
What was the ecu issue? I have never touched any of my tables aside from boost, but I have similar issues.
Revs drop slowly and hang a bit or rise when I shift.
Sometimes the car sticks around 2000. If I rev or turn on my AC it'll go back down.
Old Feb 27, 2014, 08:46 PM
Pirana's Avatar
we will never know.....
Quick Reply: throttle hang issue. need help
