Car won't stay running
I have an 03 evo I purchased off a fellow evo owner on here who decided to lie to me about all the problems, frame being bent and even miles. That said I have dumped anywhere from 2-3 grand into this thing already and had the main issues fixed. I have had it back for about a week and it's been driving and running fine.
One thing I noticed though was when it had been sitting and I'd go to drive it, it would start up fine but when I'd go up the road it was almost as if it was missing. I figured it was the spark plugs so I bought some new ones, put them in today and now the car won't even stay running and you have to give it gas just to get it to idle. As soon as I let off the gas it shuts off... It doesn't sound the same way it did before, it has a real choppy rough idle(if I can get a video later I will). I put the plugs that were in it back in and nothing. I tried driving it and it just shut off.
I don't see how changing the plugs would cause this and was thinking it might be the timing? idk but I was wondering if anyone on here had this happen before or might know what it could be to help me in the right direction. This is ridiculous..
No recent mods, I was unable to get a code reader tonight.. The mods the car had when I got it were the following:
-Precision 880cc injectors-
-Hks 272s cams-
-Crower Titanium Springs and Retainers
-Cometic Head Gasket-
-Arp Head Studs-
-Aem intake-
-Ngk Step One colder Plugs
-Hallman Mbc-
-Espirlir Jgt 500 Cat back-
-Synapse bypass valve-
-Megan Down pipe-
-Quaff Diff-
I have an apexi turbo timer and it has an a/fr and it was reading 19 at idle..
-Hks 272s cams-
-Arp Head Studs-
-Aem intake-
-Hallman Mbc-
-Megan Down pipe-
-Quaff Diff-
if its running rough like idles rough check for vacuum lines missing or unplugged off the intake manifold, if all are there check behind tb for egr valve vacuum line. If thats good do like ^ guy said above, a boost leak test, if thats good, well might be time for a compression/leakdown test. So before you get nervous check the basics, use the manual or search for how to check each of these. good luck.
yea some guy just did a writeup about his idling problems and it was his EGR valve or egr hose leak. your idle might not be too great with those cams in the first place though. But you said it felt fine before. But you might wanna do the leak tests and might as well scan code first and see what it says might give you a better idea of what you are lookin for.
if u just did ur plugs the obvious solution is to double check your connections with the coils and plugs as well as the plug connections. i've seen it before start and run rough sounded like subie if someone didnt have good connections
Okay so here's an update.. this morning I went out and got the code reader on it and it came back with 3 codes, 2 being the same codes.
PO141 - Circuit malfunction
PO134 - Censor CKT No activation (twice)
Now the car doesn't even sound like it's trying to start, it may of fouled the plugs out I have not checked them yet.. I was told it could be valve springs or boost leak. I'm not completely sure where to start on these problems or where to look yet so I'll just keep researching I guess.
The car had NGK R plugs (BPR8ES) and I was putting in Autolite double platinums (APP63), thinking nothing of it. The gaps weren't the same but I adjusted the new plugs so they we pretty much even. Even after putting the old plugs back in nothing, so something else must of happened. The old plugs were getting spark when we tested them but the newer ones weren't.
Edit: found this site but not sure which one to order?
http://www.autopartswarehouse.com/se...gen+Sensors%29
