spark plug gap question.
i was running alot of aftermarket goodies. have since had problems and worked backwards by putting my car to stock. did a stock flash but now it breaks up very badly when hitting boost with high load.
my question is can my gap of .020 be causing my problem with a stock tune?
horrible advice. you dont raise the gap if its blowing out spark, you lower it.
see if .018 fixes it. i wouldnt go any tighter then that though. if that doesnt fix it, then change the plugs.. if that still doesn't
fix it, then your ignition is probably shot or you have some kind of ground issue somewhere.
horrible advice. You dont raise the gap if its blowing out spark, you lower it.
See if .018 fixes it. I wouldnt go any tighter then that though. If that doesnt fix it, then change the plugs.. If that still doesn't
Evo8you2007
Mar 7, 2008 02:19 PM
