oil pressure sensor?
can somebody post a pic of where this is located?
im putting my car back together after a year of it being apart..
i now have a 2.4 block and have the plug sitting by the alternator but cant seem to find the sensor?
did map delete it?
do i need it?
will oil randomly shoot out of something when i go to start the car haha
do 2.4s not have a spot for it?
or am just not searching the right place and looking over it..
any help apreciated.
did map delete it?
do i need it?
im trying to figure out where the electrical plug goes.. the plug is located within 4 inches of the alternator electrical connection.. i was told it was the oil pressure sensor..
il have to take a pic of the plug tomorow.
somebody plz post a pic of the oil pressure sensor..
this is the plug im unsure about (located a few inches from the plug that goes into the alternator)
is this a knock sensor? either way i have that hooked up as well
i found this port blocked off in the block.. as well as the sensor above it is connected. which sensor is this?
somebody tell me where the plug goes or if im missing a sensor or something needed..
That plug is for the Egr sensor, the other sensor is the knock sensor thatshould go to the left side lower part on the intake mani. The oil psi should be belove the rear balance shaft to your left you should be able to see a open hole. Gl.
Evokid03
75
Jun 5, 2019 01:35 PM
CeliOnce
16
Mar 19, 2016 07:54 AM
boosted91t
27
Jan 20, 2015 07:44 PM
