03 Evo 8 Front Brake Problems
Hi guys, I just bought an 03 Evo 8 yesterday. I tried replacing the front brakes today since it made grinding noises and the pads looked really thin. I replaced the front brake pads with an autozone duralast gold brand and had the rotors cut. After installing the brakes, it still made that grinding noise that sends vibration to the brake pedal. Now what I'm wondering is that, should I have used a different set of brake pads? Should I buy a different brand since the duralast golds may not be compatible with the brembo brake system? or would it be the brake caliper? it makes a really loud grinding sound when brakes are put on at a low speed, then after driving the car for a bit, the noise disappears but the front brakes don't seem to be working very well. Please I need your help, it's a real safety issue and I'd like to fix it. I'm not very familiar with the brembo brake system. I'd appreciate it if any of you would share your knowledge. Please respond, thank you.
I would never personally run any pads on my evo from autozone unless they were selling hawk pads. Even so, you can find better deals online through the vendors. Did they measure your rotors and ensure they were in spec? Honestly I'd get new pads and rotors. If you're on a budget girodisc has a bailout package for some affordable rotors and pads.
EJEvo
May 21, 2014 07:57 PM
funks
58
Dec 20, 2012 11:34 AM
bdonIX
Dec 18, 2012 02:22 AM
tsitalon1
73
Dec 12, 2010 11:54 AM
