Evo8 Strange Idle, WOT, de-cel afr..
Ok guys, I've had 3 Mechanics< COUGH look @ it with their opinion but since I live where everyone has a mustang.... Everyone saying nothings wrong....
That said.
UPDATED
IDLE: The car is at 14.2-3 Sometimes it will randomly jump up to 18.x or Drop to 12.x & almost die rpms drop to around 500 rpms I've noticed.
Fixed so far. one plug was fouled & it wasn't tightened all the way was leaking oil from around it. Now it holds a pretty constant afr of 14.3-14.5 Any suggestions on getting my Idle afr up & my normal driving fixed?
Driving: holding 13.9-14.5
De-Cel: Fixed
I've notice that the boost gauge has been stuck @ 0 sometimes. this is a Defi unit. If i blip the throttle @ idle it will finally hit vacuum @ drop to 18.x
This is all with the AC on MAX**
Mods are listed in cig. I've ordered a boost leak tester but I've already double checked all the vacuum lines im guessing a gasket? TB seal? The cars @ 99k mileage. Timing belt was change @ 80k.
Thanks for any info or things I should look for.
I should add non of these issues came til after the EGR delete. afr was 14.5-7 , WOT 3rd gear was 11.3-5s. I think Boost leak test & probably a better tune?
That said.
UPDATED
De-Cel: Fixed
wtf 21 afr's? you must be kidding. your motors gonna blow running that lean man this isnt a simple boost leak problem. you have any lights or anything? misfiring? running that lean is asking for serious trouble
The point of why its still spraying fuel while on de-celeration is what i dont understand maybe injector leaking? or vacuum leak causing it to be rich?
Its actually not lean at all it was 10.5s until I re adjusted a/f in the ecu after the egr delete. I'm starting to think I should put the egr back on...?
Do this when you let off the accelerator and it stays rich put your foot behind the pedal and lift up...Does it go full lean like it should?? If so adjust the throttle cable behind valve cover.
You'll see 2 bolts holding it on an adjustment bracket. FSM outlines proper adjustment but you can adjust as desired if that is your issue.
to ad to the other post:
No this is at any gears any time , its random as to why I think it is a leak from the intake manifold?
cars boost cut is set @ max, cars running 25psi on 93 octane no knock counts, has a walbaro fuel pump. Think something do to with injectors? the car does have 99k on it.
I've been driving the car very slow so that it doesnt go out on me, until I get this worked out. I tought I found the leak the mbc had a oring that was torn, but that didn't fix the issue. The fact that its going crazy @ idle is what give it away. it shouldn't jump to 18x. or drop to 12 while @ idle it makes no sense.
I did reset the throttle cable bracket completely. It's Idle is very weak I think I'm going to try some different plugs, The De-Acceleration was fixed by loosening up the bracket. It goes to 21.8 < on de-cel like normal so the throttle was basically stuck opened a little...
But I still get the random rich or lean spurts for a few seconds I can feel the cars power reduced when it goes rich very badly the car just feel like it fell flat. Maybe plugs are causing timing issues? would explain the crazy idle i guess?
Anubis18
May 9, 2013 07:17 PM
