Buscher ported tb vs Milspec?
Old Dec 10, 2012, 12:33 AM
Grimgrak's Avatar
Since I can't find much on the buscher ported TB. Was wondering if it has all the stiff the milspec does.
Old Dec 10, 2012, 08:24 AM
thepoint4life23's Avatar
Many People run the Buschur tb. and are super Happy with it. its one of the best on the market
Old Dec 10, 2012, 08:28 AM
Kracka's Avatar
Mil.Spec's comes standard with brand new high-pressure seals. Unless something has changed, Buschur only replaces seals that are worn, and uses OEM Mitsu seals unless you pay additional for aftermarket high-pressure seals. Buschur's plate also seems to fit tighter and it can get stuck/sticky after it sits.
I had Mil.Spec's on my IX and it worked flawlessly; so I bought one for my X too.
*edit*
After checking Buschur's website it now appears that they use new high-pressure seals in their ported throttle bodies.
Old Dec 10, 2012, 07:17 PM
Grimgrak's Avatar
Yeah my BR ported one seems to get stuck on initial engagement of the throttle really annoying. I'll poop a brick if they make me send it back to be "rebuilt"
Old Dec 12, 2012, 02:00 PM
Philly's Avatar
yea my br ported get stuck alittle too -_- anyone know any solution to it it rev a bit higher like 1800-2000rpm when i let go gas pedal coming to a stop tap the gas pedal again and it closed fully
Old Dec 12, 2012, 08:54 PM
Grimgrak's Avatar
After a little sandpaper mine sticks only when the car is on and when the car is off it's fine... really frustrating.
Old Dec 12, 2012, 11:00 PM
Xtsy's Avatar
wow that sounds like a issue, anyone having any problems with the milspec?
Old Dec 13, 2012, 06:49 AM
Bramage_Dained's Avatar
There's no issue with the BR TB on my car.
Old Dec 13, 2012, 04:09 PM
Blue Evo 8's Avatar
I have the Buschur ported T-body also, and have the Milspec high pressure seals.
I then installed it with Buschurs ported intake manifold.
No complaints here!
But either way, you can't go wrong with either.
Aby@MIL.SPEC
Evo X Dyno Results
19
Oct 9, 2014 06:44 PM
yeayeaatou
36
Jul 6, 2013 11:08 PM
sonic_evox
Oct 12, 2012 09:57 AM
L888Apex
Jan 18, 2010 07:22 PM
CO_VR4
Aug 5, 2009 09:28 AM
Quick Reply: Buscher ported tb vs Milspec?
