Need Advice ASAP! Relay clicking, gauge cluster always lit with no key in!
It just started happening tonight.. My battery was dead, tried charging, wouldn't take a charge, replaced battery. Car fires right up, drives fine, I turned the car off. The second relay down in the slim fuse box located in the engine fuse box is clicking, my injectors click on and off and my gauge cluster is constantly on!?!? the only way to stop it is disconnecting the battery.. I re grounded the ground wires, check fuses, nothing!.. I stopped hearing the clicking but, the gauge cluster is constantly on.. i started my car, drove it around the block, came back home, turned the key off, pulled it out and the engine kept running.. after a couple seconds it shut off.. Lmao, i've never had this happen.. car was running 100% till tonight when my battery was toast..
Thanks in advance! Dustin
evo98urv8
Feb 8, 2015 07:03 PM
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
TGC_QS
Jun 28, 2013 12:43 AM
