Cleaning headlights?
Tried cleaning my headlights but it appears there's some weird yellowing on the inside of the lense. They're JDM 9 headlights and I would like to get rid of the residue or whatever it is. Can I just bake them to pull them apart? What temp do I bake them at and how long? Then how do I make sure they're properly sealed after?
Thanks,
Anthony
Thanks,
Anthony
How did you clean them? its unlikely that the yellow is on the inside. Go pick up a headlight restoring kit. Search the forum too there's some tutorials floating around.
I did it the same way I've been doing all my headlights. Spent about 2 hours on them and it did nothing. Started with some 800 grit sand paper wet sanded for about 10 minutes, then moved to 1200, then 1500 followed by a medium rubbing compound then a fine compound. Did absolutely nothing.
You need to go gradually all the way to at least 3000 grit. I always go all the way to 5000 grit and have crystal clear results. Also use plastic X instead of rubbing compound
This stuff is better than any kit I've ever used, and it takes 15 min tops for the whole car. Also, there is no way the yellowing is on the inside.
http://www.cureuv.com/lightrite-head...value-pak.html
Do you sand by hand or a drill type deal? Sometimes it takes a long time to get through all the crap on the lens. Definitely go all the way to 3000 or better grit when you do it. Maybe take a picture of your lights to give us a better idea of how bad they are. Like some have said the kit is the way to go its gives you all the steps and proper compound. Maybe give one a try.
Something else that popped into my head is make sure they don't have like a clear bra film on them. I've seen that yellow from neglect and it causes all kinds of issues.
I picked up a meguiar's headlight restoration kit for like $30, comes with 2 different sand paper grits, a polishing pad you put in a drill, headlight cleaning bottle and a polishing bottle, worked really well for me and i've done 6 pairs of headlights and still have product left. GL glad you care about your headlights so many people just dont care and it looks awful D=
There's a million different sources of info on this topic from detail forums.
Post photos so we can have a look.
I'd be a little nervous putting $1600 of headlights in the oven..
For anybody that has an issue with headlights sealing and has had water get into the housings and make water spots on the inside lens. Go buy a bottle of everclear, its 190 proof or 95% pure alcohol. Since it is so close to lab grade alcohol it won't damage paint or plastic. Just pour a little in the lense, swish it around and pour out the excess. The rest will dissolve leaving a clean lens. Best of all you'll have the rest of the bottle to drink
Worked at a car wash before and I had mine done they look great, if I remember what grits so I apologize
All wet sanding with a compressor and dremal flat tool
Heavy grit sand paper
Medium grit sand paper
Light grit sand paper
Then 3m compound
1st buffer the headlights with polish pad
2nd polish the headligts with a polisher cream
Its been awhile but if you look up 3m products you should find them.
Then 3m compound
