SES light issue.... in reverse!!! plz help.
as the title says, i have a reverse SES light issue. I tried to take my car in for a smog check and the person there said that they didnt want to do it cause the service engine soon light doesn't come when you turn the ignition to the on position. He didn't want me to waste my money in case there a was a code or something. if there is a code the computer will automatically fail the car and i would then have to pay. so i checked and there wasn't a bulb. i put one in and still nothing. is there a fuse connected to the light or a certain something people do to turn it off? any help would be greatly appreciated.
oh and to add, i bought the car the way it is. so i know nothing of what the previous owner did to it. only thing i did was change the exhaust from super loud 2.5 inch to resonated and quite 3 inch.
alright so i replaced the bulbs and used a light tester to make sure it lit up. i also checked to see if there was continuity. that was good too.
ill try to get the car scaned later. i hope theres no codes.
sorry about the reverse thing. before i posted i of course did use the all mighty SEARCH button, and all i got was "SES light on what do i do?" "SES light! what now?" "What is Service Engine Soon light and how do i turn it off?".
But unfortunately for me my SES light does not even come on at all. There for i cannot smog my car in the state of california which i live in.
the in reverse part is just the opposite of what every one else is looking for (how to turn it off)
im looking for how to turn it on.
the wires have continuity, the bulb works(checked with light tester) and i just had the car scanned today and i do have a trouble code o2 sensor #2 which is the rear o2 sensor. apparently my car does not have one (i bought the car the way it is with minor changes).
which brings me back to my question,
How do i turn the SES light on?
even with the trouble code it doesn't light up. are you able to turn off the SES light by flashing the ECU? is there a way to tell if the ECU has been flashed or not? i really dont want to spend $300 on another stock ECU just to check if its that or not.
All the dash lights should illuminate when you first turn the ignition on. So, does the SES light come on then?
You can program the ECU to not check the rear O2 but then there would never be a code.
bulb is good. i switched it with one that lit up and also checked it with a circuit tester and it lit up too.
i replaced the missing rear O2 sensor and now there are no codes. but even then, the pre SES light still does not light up.
about 2 years ago my wife had a shop install a viper alarm. think that that might have done something to it? it does have the auto start installed as well.
