Water Temp gauge, Where to put sender?
I was going to instal an after market water temp sender and i see two ports on the OEM housing. I assume the one wire version on the front is the OEM gauge sender, but the Autometer senders threads didnt match. The OEM sensor is smaller thread.
I noticed a larger sender on the back side, where does that go? to the ECU (can read water temp on the OBDII scanner)
If i were to pull that out and use that port for my Autometer sender would that cause a CEL?
I have one of the aluminum block to cut your radiator hose and splice it in the middle. But that is after the T-stat and it would be nice to have the temp before the t-stat. Would help alarm me if the t stat were to fail. Also cutting up my new Samco Hoses and putting a huge aluminum block in there just is not a clean instal.
If you are looking for an easier way than taking of the housing and tapping it they have couplers that you can cut the radiator hose and install them in the hose that give you a port for the wt gauge. I'm using one in my truck since it's old as hell and the gauge on the dash crapped out. I've had it in there for 2 years now and never had it leak.
trinydex
141
May 18, 2018 09:34 AM
mrwickd123
Evo X How Tos / Installations
11
Nov 2, 2016 10:19 PM
SilentCool
Lancer Troubleshooting
Sep 22, 2015 05:57 AM
EGbeater
34
Mar 1, 2015 09:52 PM
