Question/Concern regarding brake pads.
Old Jan 6, 2014, 08:07 PM
Syringe's Avatar
Ok.. I'll do my best to explain the situation, looking for a little insight/assistance.
I swapped the pads on my car shortly after I bought it (<1 year), I don't know what was on there before, I purchased the car used and did not notice a brand or anything on the pads when I swapped them.. but that's irrelevant.
I swapped them to Autozone's Duralast Gold (the metallic, not ceramic) and they were just fine, then I had my calipers coated, swapped the calipers (& pads) - after I did that they had an obnoxious SCREECH at low speed gentle braking.
Note: The city had also put some surfacing crap on my street that left little rocks, so when I swapped them to the new calipers I noticed there were some gouges in the pads.. didn't think anything of it until the screech.
SO! I took the pads to autozone (lifetime warranty as long as they arent metal to metal) and got a new set, swapped them out over the weekend.. and AGAIN the screeching is there.
My thoughts... Did I possibly glaze the pads? I have not jumped on the brakes hard enough that (from my experience with motorcycles) would cause glazing in.. 30 minutes of driving.
Might be the rotors? - But I never had any issues with it before.
Hope this is enough detail, any help would be MUCH appreciated.
2006 Evo 9 MR
Old Jan 7, 2014, 05:24 AM
Shortbus115's Avatar
Did you have the rotors turned?
Old Jan 7, 2014, 09:16 AM
Biggiesacks's Avatar
Did you bed in the pads?
Old Jan 7, 2014, 09:20 AM
Sev
Sev's Avatar
+1 on bedding them in properly.
Old Jan 7, 2014, 11:47 AM
Syringe's Avatar
I did not have the rotors turned.
I will re-look into bedding them.
Thanks for the replies guys.
Old Jan 7, 2014, 06:48 PM
Jush's Avatar
Turn your stereo up, that'll make it everybody elses problem.
But seriously just go for a hard drive. that will bed the center of the pad in and do some light braking in traffic or something and that will sort the outside of the pad.
Old Jan 8, 2014, 03:40 AM
Bhsj13's Avatar
honestly, i would not buy from autozone. You should get some stoptech's man.
Old Jan 8, 2014, 05:55 PM
MRolla's Avatar
You buy cheap pads from auto zone and expect not to get noise from the pad. You bought metallic pad which will make noise no matter what you do. Its a harder compound then ceramic pads. All auto zone pad make noise trust me I get cars in everyday with customer complaints about they just did the brake and they make noise
Old Jan 8, 2014, 06:26 PM
Jimmy Javelin's Avatar
If bedding and rotating doesn't work, id look into buying new shims or cleaning them/lube. Seems the bottom line is somehow, the issue is the caliper grabbing the rotor. Shims are supposed to reduce vibration/friction (someone correct me if im wrong)
Old Jan 9, 2014, 07:53 AM
Syringe's Avatar
I was just looking for a quick swap at the time, I might look into getting a different pad in the near future if I cant get it to go away.
I could understand if there was some noise, but this is like nails on a chalk board amplified 10x
Old Jan 9, 2014, 08:12 AM
spiderseth's Avatar
for the most part always good to turn the rotors when changing the pads, and like they say you get what you pay for spend a little bit extra you wont be upset.
Old Jan 9, 2014, 04:22 PM
12secDD's Avatar
Buy quality brake pads that should be on your car. Little to no noise...
Old Jan 9, 2014, 05:22 PM
MRolla's Avatar
Yup that's normal noise for cheap pads sound like metal on metal ever time you hit the brakes
Old Jan 9, 2014, 06:56 PM
Bart671's Avatar
I loved the screeching noise Hawks made on my VIII. Made me feel like I was a rally car driver. Consider yourself lucky.
Old Jan 10, 2014, 06:56 AM
GTijoejoe's Avatar
O....then I had my calipers coated...
What does this exactly mean, powdecoated? Repainted?
This is likely the cause, the clearances inside the caliper are very important for the pad abutement, did they replace the steel abutement? did they 'coat' over it? (that would be a mistake)
Quick Reply: Question/Concern regarding brake pads.
