Radiator or Not?????
I punctured the thing in front of the radiator that looks like a radiator. Above the intercooler. It was pressurized, and when punctured hissed and spit out green liquid. I know what the radiator & intercooler are and this wasn't it.
In order to search for parts/repair I'm hoping someone can first tell me what it was that was damaged.
I realize this an incredibly stupid question but I gotta start somewhere.
AC Condenser
Thanks. A condenser it is. Now its a question of finding the best one to replace it. ANy suggestions? Should I take the time to replace the radiator as well? They don't seem that expensive.
Do you know anything about recharging the a/c system? Not trying to be an *** but if you couldn't even identify the condenser I have to wonder. You need to pull a vacuum on the system for a while to remove the water that has entered the system after it was opened, then you need to properly fill the system to the correct pressure using manifold gauges.
Absolutely this needs to be done properly with an a/c refrigerant evacuation and refill machine but it sounds like since he just removed everything from the system that isn't his plan anyway.
evotris
May 26, 2014 01:52 PM
superkizuna
30
Mar 19, 2014 08:09 PM
Onkar02
Jul 15, 2009 10:09 PM
