Intake pipe size and verifcation
I know this has been talked about a lot and there really isn't a concrete response.
I'm running an aftermarket K&N intake pipe with filter. I know a lot of people say that the aftermarket piping could cause issues with boost and what not. I've also heard that the K&N setup is also not a very good setup for the car due people's reasons.
I need some feed back, should I change it out for something else? Can I run a bigger size intake pipe and filter with stock maf?
I'm at a position where I don't know which route to go or if I should just leave it be.
I've been looking at a lot of intakes but since I'm running stock 9 turbo and stock MAF is it worth it to go bigger and or switch to another setup?
Thanks
Thanks
1 Post
ditch the MAF and do a speed density tune with a 4" intake pipe and don't re-circulate the BOV. But honestly not alot of power is made by doing an intake on these cars, alot of people can turn 400hp out of the stock airbox with a K&n drop-in filter, most of the cali guys do that because of the visual inspection. It would help if you list ALL of your mods, and your goals for the car and then we can make a suggestion, but my suggestion is ditch the MAF early on, a good tuner can make the car more drive-able without the MAF on speed density.
Currently, I have that K&N intake setup with pipe, ETS UICP, LICP, FMIC. Full turbo back exhaust, stock exhaust manifold/o2 housing. Also have warlbro 255 filter. At this time the car is untuned and i drive it on occasion.
My goal is make it a track car, road race setup, time attack if you will. At this point in time, I was planning on keeping a stock turbo setup or aftermarket stock setup(fp green etc..) because I don't want to dump TONS of money turbo wise because to me its not worth it to go big, especially on a class that works on faster spool in and out of corners.
I'm located in FL and do have 93 octane handy, e85 and e98 readily available also. EDITED LOL just realized you have FL location too! haha.
tbh i guess I'm looking for guidance on setup also.
blackgsx01
Jun 15, 2014 03:48 AM
a4rontran
Jul 26, 2011 11:11 AM
HighwayStarX
30
Aug 9, 2010 09:19 PM
